Thread: Want to lower your car? Look in here!!
Page 17 of 29 FirstFirst ... 7151617181927 ... LastLast
Results 321 to 340 of 575
  1. #321 Re: Want to lower your car? Look in here!!
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    i have 400's in the front and 350's in the back
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  2. #322 Re: Want to lower your car? Look in here!!
    then you're doing something wrong. that should be plenty of spring to go lower.
    what are you rubbing on? because you're not bottoming out the struts and running on the bump stops with a 1 finger gap.
  3. #323 Re: Want to lower your car? Look in here!!
    Jul 2010
    Montreal
    I dont know man its really weird... the noise is like metal to metal... BANG BANG, you get what i mean?
  4. #324 Re: Want to lower your car? Look in here!!
    It's a hooker with a hammer.
  5. #325 Re: Want to lower your car? Look in here!!
    I hit the bumpstops probably once every 5-7 miles
  6. #326 Re: Want to lower your car? Look in here!!
    North Jersey
  7. #327 Re: Want to lower your car? Look in here!!
    SE Level Member Konvinced89's Avatar
    Layton, UT
    I have them but i have struts which apparently raise the car.
    So my car went up about a quarter of an inch.
    Which isn't bad considering I was having ground clearance issues.
    How do different struts change the height? I thought that's what springs are for...
  8. #328 Re: Want to lower your car? Look in here!!
    Quote Originally Posted by Konvinced89 View Post
    the body is different lengths. that's the only way.
  9. #329 Re: Want to lower your car? Look in here!!
    Bilstein Monotube Shock Absorbers and Struts for 2002 PONTIAC GRAND PRIX | AJUSA.com
    front bilstein:
    • Collapsed Length: 11.67 in / 296.3 mm
    • Extended Length: 16.67 in / 423.3 mm
    rear bilstein:
    • Collapsed Length: 16.94 in / 430.3 mm
    • Extended Length: 23.48 in / 596.3 mm
    front monroe: Product Details Page
    Compressed Length 10.250"
    Extended Length 16.625"
    rear monroe: Product Details Page
    Compressed Length 15.500"
    Extended Length 23.125"
    They have less travel, collapsed height isn't as small as stock.
    So you end up a little higher.
  10. #330 Re: Want to lower your car? Look in here!!
  11. #331 Re: Want to lower your car? Look in here!!
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    so.... i want to go airbags. is it best to buy a whole kit or piece together one? is it pretty much gonna be like $2200 or can it be put together cheaper?
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
  12. #332 Re: Want to lower your car? Look in here!!
  13. #333 Re: Want to lower your car? Look in here!!
    Sep 2011
    Vancouver
    99 R34 skyline
  14. #334 Re: Want to lower your car? Look in here!!
    i would call and ask on that one. seems like more of a universal kit. i've seen that one before and i'm not sure.
    i would assume the UAS kit would be better assembled.
  15. #335 Re: Want to lower your car? Look in here!!
    Sep 2011
    Vancouver
    99 R34 skyline
  16. #336 Re: Want to lower your car? Look in here!!
    Ontario
    Does anyone know off hand which are the "shortest" struts?
  17. #337 Re: Want to lower your car? Look in here!!
    Sep 2011
    Vancouver
    i think koni's are
    99 R34 skyline
  18. #338 Re: Want to lower your car? Look in here!!
    Ontario
    Hmm...That's good to know.
  19. #339 Re: Want to lower your car? Look in here!!
    North Jersey
    ok. its official.
    i need to do something about my rear fenders.
    i'm tired of rubbing on EVERYTHING.
    help?
  20. #340 Re: Want to lower your car? Look in here!!
    Ontario
    Quote Originally Posted by jerZcavy4120 View Post
    ok. its official.
    help?
    What kind of wheels are you running? How saggy is the rear end? Or do you have 5 people in your car at all times?
  1. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  2. rear end lower
    By 52 picup in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:54 AM
  3. how to lower?
    By 89prix in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 07:17 AM
  4. Lower
    By 98GPGT in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 07:45 PM
  5. Lower KR ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 09:04 PM
