Thread: Want to lower your car? Look in here!!
Page 13 of 29 FirstFirst ... 3111213141523 ... LastLast
Results 241 to 260 of 575
  1. #241 Re: Want to lower your car? Look in here!!
    MA
    thanks drunkie. ill just do the spacers.
    SMGPFC Member #9
  2. #242 Re: Want to lower your car? Look in here!!
    shorter dogbones will also destroy the motor mounts faster.
    SE Level Member tomasz26's Avatar
    Aug 2011
    detroit
    Great information on here!! I have a 2004 grand prix gt and I really want to install lowering springs. I have 19inch rims with 1inch spacers and I am afraid of rubbing issues. Also I live in Michigan and like to put on snow tires in the winter which have 1.5 inch spacers for just the front wheels. Does anyone have some advice to help me properly and safely lower my car!! Thanks
  4. #244 Re: Want to lower your car? Look in here!!
    SE Level Member GTPNY's Avatar
    Jul 2011
    new york
    Has anyone bought these springs from the Wbodystore?
    W Body Store
    They don't seem to have a brand name.
    I cannot find any pictures on the web either.
  5. #245 Re: Want to lower your car? Look in here!!
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by GTPNY View Post
    W Body Store
    From another site.
  6. #246 Re: Want to lower your car? Look in here!!
    SE Level Member 2007Spareparts's Avatar
    Oct 2011
    United States
    I have a question about lowering the car and the cars' turning radius. My stock setup (wheels/tires) were 225/60/16's. I upgraded to 235/40/19's, keeping some meat under me and the combo overall diameter the same. What's the lowest I can still effectively lower the car without hindrance?
  7. #247 Re: Want to lower your car? Look in here!!
    Waukesha, WI
    wbs is SSC springs
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  8. #248 Re: Want to lower your car? Look in here!!
    Quote Originally Posted by 2007Spareparts View Post
    you can go all the way to the ground, but its going to take modifying the fenders and running weird alignment settings.
    i ran eibachs on my car with 19s (245/40/19). once i rolled the fenders i never rubbed again.
  9. #249 Re: Want to lower your car? Look in here!!
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    I saved up my money and i think i've decided on the held coilovers, but ive been thinking on maybe going with heavier springs than what are default i guess. do you guys have any suggestions or advice about that or maybe how heavy i should go? and also does anyone know if its cheaper to buy from held or zzp? maybe zzp has a coupon code right now?
    Thanks
  10. #250 Re: Want to lower your car? Look in here!!
    Jan 2009
    Tallahassee, FL
    ZZP sells Held coilovers IIRC
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  11. #251 Re: Want to lower your car? Look in here!!
    Donating User Odi's Avatar
    Chicago South Suburbs
    no, dont get them off zzp. buy directly from held.
  12. #252 Re: Want to lower your car? Look in here!!
    ^^^ that.
    dont give ZZP your money when they don't even build them.
  13. #253 Re: Want to lower your car? Look in here!!
    Raleigh, NC
    Alright thanks. And what about going with different weight springs? I want it to be pretty stiff and i want to go pretty low so i was thinking that might help bottoming out issues a little bit
    The spring rates are pretty good as is. You don't need any stiffer, really.
  15. #255 Re: Want to lower your car? Look in here!!
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    hopefully when i take my car out from storage i will install coilovers, is it possible o be able to tuck my bullits? 36+ offset? i got 235-55-17 now and hopefully later 245/45/17
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  17. #257 Re: Want to lower your car? Look in here!!
    Dec 2010
    Minnesota
    Anybody have any experience with the Intense coilovers?
  18. #258 Re: Want to lower your car? Look in here!!
    pretty much the same thing as the held/zzp ones.
    all of the sets available are modded struts with sleeves and potentially a pillow ball upper mount. building them yourself would be easily under $500, but most people dont understand how simple it really is.
  19. #259 Re: Want to lower your car? Look in here!!
    no, intense coilovers use stock mounts and bump stops.
    not a fan.
  20. #260 Re: Want to lower your car? Look in here!!
    stock mounts arent bad when you consider the bearings used in the pillow ball mounts.
  1. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  2. rear end lower
    By 52 picup in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:54 AM
  3. how to lower?
    By 89prix in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 07:17 AM
  4. Lower
    By 98GPGT in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 07:45 PM
  5. Lower KR ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 09:04 PM
