Shortened Dogbones are garbage and DO NOT DO THE JOB CORRECTLY!
Buy the Half set of Vinnie's Spacers, and DO IT RIGHT! Full set if you get on Intrax, and yes, you can fit a full set of spacers with 3" DP and headers, I did it.
http://www.grandprixforums.net/lower...cers-1107.html
drunkie...if i ever do lower my car, you have to help me...lol
all id want to do is put some lowering springs, maybe 1-1.5 inch in front and back, and i have no idea what supporting mods you need...ive read this thread, goes over my head lol
If it goes over your head...keep reading until you get it...thats how we did it.
i mean...i get it...but, how can i remember every little thing that changes everything else if you do it wrong, i kinda like to be prepared
I lowered my car on Springtech's...I got new strut mounts and Anti-Pogo washers.
Done and done.
if you cant understand whats in this thread, dont mod ur car.
ill look into it, it just seems complicated...
do yourself a favor and spend a few hours researching suspension theories on google. you'll pick up what we are all talking about with how everything is affected. it's not all that difficult, but there is more to it than just slapping drop springs on and driving off.
dont expect to understand everything the first time around.. like bio said research. and then when you are done researching.. research some more. slowly but surely youll start to understand more and more of what you read.
If you want to do it right and this is just exactly what I did:
-Replace LCA Bushings, go to a good poly mount
-Replace the ball joints, go with Moog (In reality it might be better to just go with WBS LCA'S or Moog LCA's)
-New Struts (GR2's from some reading do well with SSC's, but ultimately going to Bilstein/AGX/Koni's would be the best option) OEM struts can not handle the task, including the Comp G struts they will give out.
-Replace all top mounts, especially the fronts. Monroe Top mounts are cheap and work well
-Pogo Washers are a must, unless you want to bounce like a ricer civic
-Vinnie Spacers, buy his full set, even if you only plan to use half, it never hurts to have the full set.
-New axles would be suggested especially if you have alot of miles on the them. (Optional, but suggested)
-Wheel bearings, Timken bearings are my suggestion. Good to do if you have alot of miles.
-Go to the solid rubber motor mounts, when installing Vinnie Spacers might as well get the oil filled ones out of there.
-Install a Shift kit (Intense/trans go), good time to change fluid and filter.
-New sway bar end links, get moogs all around, fresh rubber bushings is nice (Optional)
-Replace Tie rod outer links, I didn't do mine yet cause they are still good, but the angle does change and puts strain on those bushings where the knuckle is, Greasable bushings are nice to have
These are my suggestions to doing it right. Alot of our cars are now seeing 100k+ miles, its all worth doing it right the first time and spending the money because I believe in do it once and do it right.
We really need someone to make an LCA to eliminate the front Rubber mount. We don't have a replacement for the rubber and I think, they aren't worth **** after 50k miles. Ron Vogel made LCA's that got ride of them, but they were limited in numbers (I was lucky to score a set).
ZZP has this idea in the custom LCA's they have, but at $500 and the reliability issues they have is a bit of a problem.
Come on, someone make us some seriously nice custom LCA's that also eliminate bump steer too with adjustable balljoints...Then make us some Tie bars and Sub Frame Connectors
well, after doing some research, i sorta understand what everybody is talking about now
i am not going to go over the top with it (see above this) jk drunkie
what id like to do are some decent springs thinking B+G lowering springs, about 1.2 inch...all im worried about is if the back is going to look like its sagging...if it is going to look like that, i want springs that wont do that
W Body Store
then im looking to get KYB GR-2 twin tube struts, it says they ride good with lowered cars...what are the springs that go best with these? SSCs?
W Body Store
im not going to go with shortened dogbones, heard too many bad things about them to buy them...i have no idea what to do for the spacer part...link please?
definetely getting anti-pogo washers, no doubt in my mind these will be going on my car no matter what
W Body Store
is there anything else i need? like i said, id like to keep it not over the top, maybe under $500 if i do it right...thanks for reading
Eibach's are about the only springs I've heard that don't sag as bad, B&Gs aren't too bad for it.
Where to get the Vinnie spacers are here, it has a link with description on how to install them in the second link:
Everything else should work, just expect that over time you will have to replace other parts, bearings, axles and other parts. But you should be able to do a while depending on mileage of the car.
