Thread: front end noise, hub?
Results 1 to 9 of 9
  1. #1 front end noise, hub?
    GT Level Member hourang's Avatar
    commerce, mi
    i think my hub is shot what you guys think?
    YouTube - Hub noise gap
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  2. #2 Re: front end noise, hub?
    commerce, mi
    anyone know? im going to autozone tonight.
    -Jeff
  3. #3 Re: front end noise, hub?
    Kansas
    Take off your tires and see if the rotor will move back and forth. I had similar problem but wasnt near as loud and ended up being my rear hub.. If you can take off the wheel and just see if the rotor and hub shake back and forth that may be your problem. Plus the roads your driving on look pretty ****ty
    SOLD 1999 GT Silvermist TS
  4. #4 Re: front end noise, hub?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    That's DEF not a bearing hub. Bearing will grind and tick. That almost sounds axle related.
    Here's a vid I made from my wheel bearing install though if you want to use it to help toubleshoot
    YouTube - How to tell if you have a bad wheel bearing
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  5. #5 Re: front end noise, hub?
    commerce, mi
    Quote Originally Posted by ninnyGTP View Post
    you win, it was the axle boot that shreaded and was banging against everything. i cut the boot for now, no noise. will have to replace the axle soon.
    ive replaced wheel hubs before and i couldnt think of anything else that would cause the noise, didnt even think of the axle boot as ive never had one go bad and most cv boots dont have the think rubber these do, due to the shape of the ujoint section. after i checked the wheel to see if the hub was bad which its solid as can be, i noticed grease everywhere and the boot shreaded and felt like an idiot.
    also my sway bar snapped by the end link. must be a common failure point. oh and my tie rod end is bad.
    -Jeff
  6. #6 Re: front end noise, hub?
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    call "morad " for a replacement. advance axles on the pass side is wrong,,,,i know this
  7. #7 Re: front end noise, hub?
    commerce, mi
    Quote Originally Posted by badbrad View Post
    dont they just sell used parts? a new rebuilt one is like $89 at autozone. i have no idea what you are saying about advance axles???
    -Jeff
  8. #8 Re: front end noise, hub?
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    Quote Originally Posted by hourang View Post
    a new Cardon one at Rock Auto is $50 (either side). I've had one in my GTP for several years and 20 or 30K miles without issue.
  9. #9 Re: front end noise, hub?
    commerce, mi
    Quote Originally Posted by Vegas~Blown View Post
    sweeet thanks!
    -Jeff
  1. Clunking noise in front end 04 gtp!!!!
    By justin98 in forum General Tech Discussion
    Last Post: 11-08-2011, 03:19 PM
  2. Right-Front Grinding Noise
    By cowmilker08 in forum General Tech Discussion
    Last Post: 06-07-2010, 01:36 PM
  3. noise in front end, left side
    By Jimbo in forum Introductions/Noob Questions
    Last Post: 08-14-2009, 04:21 PM
  4. Roar noise from front end
    By markh in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:37 AM
  5. Strange noise from front wheel
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-09-2009, 05:43 PM
