Thread: subframe swap
Results 1 to 5 of 5
  1. #1 subframe swap
    London, Ontario, Canada
    I was looking around and cant seem to find an answer so I figured what a better place to ask. Anyways I have a 00 gtp and was thinking of swapping the steel subframe for the newer aluminum one. The question I have is will the newer aluminum subframe be able to stand up and would one off of a 00 monte carlo work.Also with regards to suspension as mine seems to ride very stiff hopeing the lighter aluminum subframe will help with this. Any help is appreciated. Thanks,
  2. #2 Re: subframe swap
  3. #3 Re: subframe swap
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    FYI, the aluminum subframes have a tendency to crack.
    Where do they usually crack? Can they be beefed up in that area?
  4. #4 Re: subframe swap
    Wooster, Ohio
    they crack in all the corners were GM left massive gaps, and there recall fix is they fill the holes with a type of seam fill instead of aluminum welding them shut to fix the problem, i've even heard of guys using expanding foam and jb weld on em. I would recommend keeping your steel frame for sure for the amount of headaches you may endure on not only the swap over but if it does crack
  5. #5 Re: subframe swap
    and the more power you make the more easily youll crack it.
  1. Top swap
    By Howie05 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2012, 11:40 AM
  2. gto swap
    By CHAMPS97 in forum General Tech Discussion
    Last Post: 09-05-2009, 12:11 PM
  3. Subframe Bolts
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2008, 04:04 PM
