Thread: new back brakes. Hows the summit racing rotors?
Results 1 to 3 of 3
  1. #1 new back brakes. Hows the summit racing rotors?
    SE Level Member mxthunder's Avatar
    NE Ohio
    Does anyone have any experience with the summit cross drilled rotors?
    Summit Racing SUM-DSEP-55039R - Summit Racing® Extreme Performance Cross-Drilled and Slotted Brake Rotors - Overview - SummitRacing.com
    wondering if they are a waste for the rear, or if I would be better off going with something from power slot, or just the standard napa stuff.
    I was also going to pair them with some EBC "redstuff" brake pads.
    EBC Brakes DP31122C - EBC Redstuff 3000 Series Ceramic Brake Pads - Overview - SummitRacing.com
    Thoughts?
    Autolite 103 plugs, PRJ 8 gauge wires, 160* drilled tstat, Digital Horse Power Stage 1 PCM, Voltage booster harness, 3.25" pully, ZZP S.S. IC, Desert Fox tranny cooler/Thrasher shift kit, Wizair CAI, SLP headers/full system wrapped & coated, 3 gauge pods: A/F, Boost (16.5 lbs), comp G. 17" 04 GTP rims
  2. #2 Re: new back brakes. Hows the summit racing rotors?
    the rear doesnt help with braking all that much so drilled/slotted rotors would mainly be for show.
    also, for your street car i think the red's are a little extreme. i had green's on my car and they worked great, i would recommend those.
  3. #3 Re: new back brakes. Hows the summit racing rotors?
    NE Ohio
    Yeah, maybe ill save a little money and go with those. Ill spend the extra on the fronts when it comes time to do them.
  1. l67 SUMMIT SELLS ARE PISTONS!
    By GTPJOE90 in forum Shops and Community Heroes
    Last Post: 08-16-2009, 03:06 AM
  2. Back brakes!
    By J4pro2001 in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2009, 12:20 AM
  3. Brakes and Rotors
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2009, 11:22 PM
  4. How bad is it to run 12" rotors, Front & Back?
    By Incomudrox in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2008, 06:59 PM
