Thread: suspension replacement
Results 1 to 10 of 10
  1. #1 suspension replacement
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    it time for me to get new shocks and struts is there any way for it not to be slow low in the rear? also what do you recommended for suspension? i was looking at the kyb gr2 struts
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: suspension replacement
    Charles City, IA
    I have kyb gr2 struts and vogtland springs coming for mine.
    SMGPFC Two Nipple General
  3. #3 Re: suspension replacement
    Grayslake
    vogtland? are they lowering or stock
  4. #4 Re: suspension replacement
    Charles City, IA
    they are the least drop of the lowering springs. They are the springs that where used on the GTX's IIRC. They also maintain stock handling.
  5. #5 Re: suspension replacement
    Grayslake
    o. i really don't want to lower my car. i just want to put new shocks and to keep the rear from sagging when i take off
  6. #6 Re: suspension replacement
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    x2 im in need of some new ones too
  7. #7 Re: suspension replacement
    GR2 are a good upgrade for stock springs, but they a little stiffer so your car will handle slightly better, but ride a little rougher. if youre a baby then just get regular stock replacements or monroe.
  8. #8 Re: suspension replacement
    Charles City, IA
    If you dont want to lower, I would just get some quick struts and not **** with taking the struts apart and putting them back together.
  9. #9 Re: suspension replacement
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Quote Originally Posted by grand2000prixgtp View Post
    Vogtlands aren't that much lower than stock. They give a nice, even gap all the way around, and look like the car should have looked from the factory (i.e. not like a 4x4). Ride quality and comfort are still good.
    If you don't want the rear to sag (common problem as GP's age), some people have gotten good results by using Intrigue rear springs with stock front springs. The Intrigue springs are higher, so even when they settle your car won't look like a dog dragging its butt on the carpet.
    Vogtland springs with AGX struts:
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  10. #10 Re: suspension replacement
    Wooster, Ohio
    quickstruts from Rockauto.com, cant beat em for what you get and still stay stock. Unless your looking for better handling to then get the quickstrut kyb's. By far the best and easiest way to go if you want stock height
  1. Replacement suspension
    By blakshukvw in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2009, 02:24 AM
  2. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
  3. Suspension 04 GTP
    By Keet04GTP in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2008, 11:12 AM
  4. Need some help with my suspension please!!
    By dementeddj in forum Off Topic Discussion
    Last Post: 02-11-2008, 07:12 PM
  5. suspension ??
    By bayareagtp in forum Brakes/Suspension/Chassis
    Last Post: 02-08-2008, 10:55 AM
