View Poll Results: Which ones?
Voters
7. You may not vote on this poll
  • TDC Cross-drilled/slotted stock replacements for $150
    0 0%
  • ZZP 12" upgrade, new equip, plain rotor for $250
    7 100.00%
Thread: Brake options
Results 1 to 12 of 12
  1. #1 Brake options
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Hey guys, wondering what your opinions are on brakes...and ONLY these two options. Please do NOT tell me to get f-body brakes b/c they are not one of the options I'm presenting.
    It's time for me to get brakes, and I need new rotors as one of mine was trashed (pad wore down to metal). I am on a very tight budget, but want to get something decent since I need new rotors..and part store rotors are a ripoff.
    From TDC Racing, I can get stock replacment rotors with cross-drilling/slotting and Hawk pads for roughly $150 http://www.topdeadcenterracing.com/P....aspx?CatId=20
    The other option I'm considering is
    ZZP 12" upgrade with the single piston caliper. This comes with new plain rotors, calipers, bolts, bushings, and powerstop pads for about $250. http://www.zzperformance.com/grand_p...=576&catid=138
    I thought the stock brakes were pretty good stock, which is why I'm considering the TDC route, as it'd be the same cost as parts store stuff, but would help on resale...as a potential buyer wouldn't care if the brakes were bigger, but looked cool ...
    If it were you, would you spend the extra $100 for all new equipment and a larger, plain rotor? I do NOT have enough money to get f-body calipers. (or cross-drilled/slotted 12" rotors)
    Thanks for your opinions.
    Jesse
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  2. #2 Re: Brake options
    i did the 12" brake upgrade from the newer monte carlos and stuff for about $60. you can get that stuff from the junkyard (all you really need is the caliper brackets) and then you can buy whatever rotors and pads you want. they work way better than stock.
    not dissing anyone above, but i vote for none of the above since you can get stuff for cheaper.
  3. #3 Re: Brake options
    Tyler, TX
    what years am I looking for? any special trim, or is it all of em?
    Well, I just checked junk yards around here...and of course, nothing. Newest Impala is an 03...bummer. The yards around me typically don't have new stuff...which sucks for me, but I could go steal the brakes off my neighbors impala SS
    Thanks!
  4. #4 Re: Brake options
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    12'" or bust
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  5. #5 Re: Brake options
  6. #6 Re: Brake options
    Tyler, TX
    Quote Originally Posted by Toofastgs View Post
    12'" or bust
    Any experience with them?
    Thanks!
    Jesse
    and the 13" kit is 12.7"........
    don't forget to cast your vote in the poll....if you have one....
  7. #7 Re: Brake options
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    12'" or bust
    i got 13s from bear.
  8. #8 Re: Brake options
    Tyler, TX
    Quote Originally Posted by DOUGLASMELTER View Post
    yeah, but I highly doubt they were under $250.... thanks for the input though.
  9. #9 Re: Brake options
    Apr 2009
    ERIE
    Quote Originally Posted by 03GTPLE View Post
    $1000 but well worth it. save up an get these instead
  10. #10 Re: Brake options
    Tyler, TX
    time is not on my side since my rotor is shot, so saving is not an option. So then, you would vote for just stock replacments...then get baers later.
  11. #11 Re: Brake options
    Dartmouth N.S.
    i'm also looking at a 12" upgrade.. All you need is just the brakets??? would a caliper also work from an 05 impala?
  12. #12 Re: Brake options
    Tyler, TX
    Quote Originally Posted by SuperChargedGTP View Post
    All you need for a 12" upgrade is the caliper bracket and rotors. I just spent this morning at the yard and did the upgrad on the 99 GT they had in the yard just to make sure everything fit. You will use your same calipers and pads.
    Here's the list (thanks to Matt5112) of vehicles that have the caliper bracket for 12" brakes:
    00-05 Buick LeSabre
    97-05 Buick Park Avenue
    97-99 Buick Riviera
    97-98 Buick Regency
    97-05 Cadillac Deville
    97-02 Cadillac Eldorado
    98-02 Chevrolet Camaro (steal the calipers too!!!)
    00-05 Chevrolet Impala
    00-05 Chevrolet Monte Carlo
    97-03 Oldsmobile Aurora
    98-99 Oldsmobile Intrigue
    00-05 Pontiac Bonneville
    98-02 Pontiac Firebird (steal the calipers too!!!)
    I'm going the 12" route as the yard had an 03 Impala , but I'm going to get the TDC rotors and pads and new caliper hardware (bolts, rubber boots, etc) just because. It'll be easy to do...just gotta wait on parts.
    Oh, and the caliper bracket bolts are the same on both cars too.
    I'll put up pics when I'm done.
    Jesse
  1. TB options
    By 4drgt in forum 04+ Specifics
    Last Post: 09-12-2009, 03:14 PM
  2. HO Alternator options?
    By Luda in forum Audio, Security & Visual Electronics
    Last Post: 09-03-2009, 02:59 PM
  3. Rotor Options
    By sirschuster in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2009, 07:22 AM
  4. Any exhaust options for '91 GT 3.1L?
    By 66custom in forum General Tech Discussion
    Last Post: 05-13-2009, 03:18 PM
  5. What are our options?
    By gdbyrd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2009, 12:17 AM
