I messed around for quite some time yesterday with my dad (who was visiting from out of town) and we could not seem to get the new front sway bar installed on my 2000 GTP. Is there a trick to doing this? Do we need to remove the tie-rod ends? We started down that path and just can not seem to get the bolts to come all of the way off. It is loose, but we broke (torqued off) the tip of the 3/8" to 1/4" socket adapter that was allowing us to use an 8mm socket to hold the tie rod from spinning while taking off the nut. Yeah, we needed to use THAT much force. We started wondering if we were attacking the problem correctly or not. I put some PB Blaster on it over night and want to tackle it again.
So, are we on the right track with the tie-rod ends? Thanks!
