I am replacing my front sway bar, i have gotten all of the bolts out to get the sway bar out but i came to a problem when trying to remove the tie rod end. In the install process that i read, it told me to remove the tie rod end on one side of the car, so that you could pull the sway bar out of one side. When removing the nut, it started to come off, then it just started spinning on the bolt.. No matter if trying to tighten, or loosen now all it does is just spin the whole thing. We have already tried using an impact wrench, yet that does nothing as well...
What should i do?
Thanks
