Thread: Steering Intermediate Shaft
Results 1 to 8 of 8
  1. #1 Steering Intermediate Shaft
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    I was talking to my buddy today and he works for GM as a Tech. and asked him if he could find out what the clunking noise that I had was... he took a look and said it was my steering intermediate shaft, so my question is how hard would that be to change? or would i be better off taking it somewhere?
  2. #2 Re: Steering Intermediate Shaft
    SE Level Member chitownchevy's Avatar
    Chicago
    Or you could try the quick easy fix to this problem before you fork out the money for a new shaft. all you need is a can of white lithium grease in an aeresol can sold at any parts store. If you look under your drivers side dash near you pedals you will see a rubber boot on the steering shaft, pull it down a little so you can spray the grease in there. Make sure the boot is back in place and go for a test drive, the clunk should be gone and you saved yourself some money. If this does not work you may need a new shaft, but this usually solves the problem.
  3. #3 Re: Steering Intermediate Shaft
    St. Louis
    thanks for the info man i will be sure to give it a try tom.
  4. #4 Re: Steering Intermediate Shaft
    Banned - Busted For Scamming
    Feb 2009
    what did the clunking noise sound like?
  5. #5 Re: Steering Intermediate Shaft
    MA
    Remove it & grease it with the right stuff then you will not have a problem with it again..GM tech shouldve told you GM makes a kit for it..I will get you a part # by the end of the day..
  6. #6 Re: Steering Intermediate Shaft
    MA
    here..
    Part# 26098237 $8.01 from Monsterpartsonline.com
    LUBE KIT
  7. #7 Re: Steering Intermediate Shaft
    Moore, Oklahoma
    Nice! What kinda grease is it anyway? Pretty thick stuff i'm assuming? I may try this on mine, though with a 170k, i'm sure I need a new shaft anyway...
    Shawn W. Larsen
  8. #8 Re: Steering Intermediate Shaft
    Aug 2008
    KCMO
    marking for future usage
  1. intermediate steering shaft
    By mstowe in forum Shops and Community Heroes
    Last Post: 10-08-2013, 07:02 PM
  2. Intermediate steering shaft?
    By 04muscle in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 07:30 PM
  3. Intermediate Steering Shaft.
    By bentendo92 in forum General Tech Discussion
    Last Post: 09-18-2008, 07:04 PM
  4. Balance Shaft
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2008, 10:42 PM
  5. CV Shaft
    By webracin in forum Shops and Community Heroes
    Last Post: 04-15-2008, 01:38 AM
