Thread: To adjust camber.......
Results 1 to 5 of 5
  1. #1 To adjust camber.......
    SE Level Member trenaro's Avatar
    Feb 2009
    KC
    Do I need camber bolts front and back or just back?
  2. #2 Re: To adjust camber.......
    GTP Level Member Scimmia's Avatar
    QCA, IA
    you need a cam bolt on whatever wheel needs the camber adjusted, or am I misunderstanding the question?
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: To adjust camber.......
    Banned - Busted For Scamming
    Feb 2009
    depends on if its out of spec, you need the kit. it will come with the bolts you will also need to wobble out the holes in the struts.
  4. #4 Re: To adjust camber.......
    Jersey
    you will need all 4. PFYC sells them and tire-rack sells them.
    16' wrx sti- stock
  5. #5 Re: To adjust camber.......
    Moore, Oklahoma
    Camber kits all the way around is the way to go.
    If you buy the right kits, you shouldn't have to drill out the holes at all, thats the whole idea behind the camber kit, to avoid doing this.
    I have plenty of adjustment with mine (been running mine for 7 years now). I run Northstar camber bolts, PN: 41-958 IIRC... 2 kits will do the whole car (2 adjustable bolts in each package obviously). If you need even more adjustment buy 4 kits and replace all your knuckle bolts with camber bolts...
    Shawn W. Larsen
  1. Camber
    By SlowM90 in forum Tires & Wheels
    Last Post: 05-14-2009, 06:01 PM
  2. Adjust headlights
    By High Rolling GTP in forum General Tech Discussion
    Last Post: 03-01-2009, 11:30 AM
  3. camber bolts
    By nemesis in forum General Tech Discussion
    Last Post: 02-29-2008, 05:10 PM
