Thread: weird noise
Results 1 to 6 of 6
  1. #1 weird noise
    SE Level Member c32k05's Avatar
    Fort Wayne, IN
    When i am slowing down and the wheel is turned to the left slightly i get a really loud rubbing noise. (sounds like metal on metal). There is also a noise when i turn left at slow speeds (20mph or less). I just replaced the wheel bearings about a month ago and have not had time to get an alignment. Could this be the issue?
  2. #2 Re: weird noise
    TDCRacing
    Guest
    No,alignment could not cause this issue.
  3. #3 Re: weird noise
    Fort Wayne, IN
    Didn't think so. Any suggestions on what it may be?
  4. #4 Re: weird noise
    Barksdale AFB, LA
    If the hubs are new, I'd inspect the suspension. Look for any worn out bushings on the control arms. Other than that, it could be one of the axles.
    2009 Subaru Impreza WRX STI
  5. #5 Re: weird noise
    Michigan
    I just answered a question similar to this one. If the sound is coming from the front, then its most likely the ABS Bracket rubbing! I have a 97 and I had the same exact problem, and it seemed louder when backing up and turning. So, my dad and I took off the front 2 tires (it was happening on both) and we noticed that the abs brackets were kind of in the way, especially when turning the wheel, they would get smashed between that and the brace under it. We worked on them by turning the wheel all the way one way, looking to see where the bracket was touching, bending it out of the way and then doing the same thing with the other wheel until both were no longer touching anything the noise is all but gone now!
  6. #6 Re: weird noise
    Fort Wayne, IN
    Well after replacing one of the wheel bearings because it was bad 2 months after replacing it and the struts it is still making the same noise but not as bad. Also when going over bumps at around 5-7 mph i get a squeaking noise or like an air noise coming from the front left (sounds like a leaking air shock). I am at a loss to what it is. I have had the suspension checked multiple times and no one seems to find anything wrong.
  1. weird noise cutting out
    By 01gtpfargo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2009, 12:27 PM
  2. Weird noise problem!
    By GTP4 in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2009, 11:41 AM
  3. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
  4. Weird noise. Dropped the car in second.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-04-2008, 12:26 PM
  5. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
