Thread: Humming Noise During Acceleration
Results 1 to 11 of 11
  1. #1 Humming Noise During Acceleration
    Donating Users Burgundyman's Avatar
    When I accelerate, I hear what appears to be a humming or slight thumping noise...The noise disappears when the car comes to a stop. I replaced both hub and wheel bearings with a brand new set (almost $300.00 later)...The noise appeared to have diminished when I took it for a test drive...It resurfaced minutes later. There is no clicking sound when I turn...It is almost like a "wobbly" sound...I am leaning on replacing both axles though I am not sure, which one is making the noise...I installed brand new tires, rotors and brakes...I do not believe the new Goodyear tires are making this much road noise. Any advice would be appreciated.
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  2. #2 Re: Humming Noise During Acceleration
    Saraland Alabama
    goodyear tires make noise (few are round from my experience working for goodyear) could it be transmission? Find a way you can support the front of the car and run it, that will eliminate tires
  3. #3 Re: Humming Noise During Acceleration
    Quote Originally Posted by archemedes View Post
    I could put a pair of jack stands under the front end and let it accelerate...But I noticed this problem before I replaced the car with Goodyear tires...I suspect that it might be an inner joint problem.
    RED- 4 Door Sedan
  4. #4 Re: Humming Noise During Acceleration
    Oklahoma
    Do you get any vibration? No clicking sound I believe would say the outer joint is good. I had one axle shaft that would cause a vibration from between 35 - 45 or so mph. Then it was good and only on acceleration.
    I didnt want to say this, but there is the possibility of a transmission issue. Thats how my tranny trouble started. A humming noise. It eventually lead to the demise of my differential it looks like. I have two threads in the 4T65E-HD section with progress and pictures if you want to see what the end result is.
    Im not saying yours is a transmission issue, but keep that in the back of your head if you go to swap the axles and the noise persists.
  5. #5 Re: Humming Noise During Acceleration
    Yikes...transmission problems scares me...I did not notice any vibrations just a hum as you accelerate and then it seems just to linger, while driving.
    RED- 4 Door Sedan
  6. #6 Re: Humming Noise During Acceleration
    Banned
    New Port Richey Florida
    Its a trans problem if its comming from the can when driving and you replaced the hub's then i'm leaning toward a bearing inside the trans has let go. But to make sure take the car to a trans shop and have it checked..
  7. #7 Re: Humming Noise During Acceleration
    Oklahoma
    I dont know how long ago you may have changed the fluid in your transmission, but it may be worthwhile to drop the pan and see if you have any metal shavings or any metal at all in there. If so, then I would get with Trannyman and get some advise from him.
    Again, not saying it is the transmission, but I would definitely want to rule that out before I go and replace a bunch of other stuff.
  8. #8 Re: Humming Noise During Acceleration
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    though, a hum and a thumping noise should be quite separate, unless youre going way fast. then a thump could turn into more of a hum.
    first thing (cheapest) and its likely not the issue, but swap the wheels/tires front to rear, just to rule that out.
  9. #9 Re: Humming Noise During Acceleration
    Quote Originally Posted by Toasty View Post
    I will give it a try though all the tires are brand new...I think I will have the Tranny guy look at it anyway. I might experiment and replace the shaft to rule out the shaft...I will rebuild the stock CV shaft or at least repack and change the booth cover....Figure it would not hurt.
    RED- 4 Door Sedan
  10. #10 Re: Humming Noise During Acceleration
    I replaced the filter, gasket and fluid last year. No problems reported during that service. The only they said was that the seal had a small leak.
    RED- 4 Door Sedan
  11. #11 Re: Humming Noise During Acceleration
    Donating Users foursixer's Avatar
    boston,ma
    i am having the same problem with my 98 gtp. have anyone been able to pinpoint the problem? i just bought the car about a month ago and thought it might of been the wheel bearings. i replace both front wheels and it did not solve the problem.
