Thread: Ball joint?
Results 1 to 4 of 4
  1. #1 Ball joint?
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    I changed my front pads today and notice play in the left wheel. When I hold the top and bottom of the wheel I noticed a little movement there's no side to side movement. Any suggestion on what this could be, didn't have time to check further something came up that I had to take care of.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Ball joint?
    Feb 2008
    yup, very likely the ball joint. It can be hard to see if your shaking the wheel by yourself so try getting someone else to do the shaking and look at the ball joint.
  3. #3 Re: Ball joint?
    PA
    Could also be a bad wheel bearing. In my 219k miles, I have never changed a ball joint and to this day, they are still good. But I have changed many wheel bearings.
    2001 GSE
  4. #4 Re: Ball joint?
    Aug 2008
    Hamilton, OH
    That's weird; I've never replaced a bearing, but I just did my balljoints at 230k. It tore up a set of tires before I noticed the wear. You get wear on the extreme inside edge of the tire that's hard to see unless the tire is removed, or you turn the steering wheel all the way over.
  1. Replacing Ball Joints
    By 98GTPCALGARY in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 05:12 PM
  2. ball joints
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 05-07-2009, 07:45 AM
  3. Steering / CV Joint?
    By Egleone6 in forum General Tech Discussion
    Last Post: 04-08-2009, 11:08 PM
  4. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
  5. Ball Joint Boot
    By JJ91284 in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2008, 11:17 PM
