Ok heres the thing,
I'm on my2nd replacement now needing 3rd hub replacement.
What is happening is #1 abs starts off fine some days then once i get past 25-30 it sets off the light. If i leave trac off i start get the low traction light. This can happen when backing out my driveway. When it wants to work it works fine but as soon as i get it on the highway its done.
#2 I am getting a grinding noise from the front left side this is the hub that has always been replaced. If i am going straight its loud. if i slightly turn my wheel when driving it goes away.
Things is is this things are not cheap. So far all my replacements have been from local salvage yards @ about 35 buxs a pop and a place to install it for 45.
Should i bite the bullet and spend 150 on a good new bearing or hit up another salvage yard.
Now i did find a hub for 100 buxs at autozone made by dynapro. So far what i read up on this that is a bad brand.
Anyone having same problems?
