Thread: Stainless brake hoses
Results 1 to 6 of 6
  1. #1 Stainless brake hoses
    Jul 2008
    N.Y.
    Ordered a set of stainless steel brake hoses. The fittings at the ends, where they connect to the hard brake tubing, were different than the stock hoses,and would not fit into the brackets.
    Does anyone make stainless hoses with the correct end fittings?
    Thanks.
  2. #2 Re: Stainless brake hoses
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by LEAD LAP View Post
    Thanks.
    Where did you order them from? I know the Goodridge lines work fine.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Stainless brake hoses
    Jul 2008
    N.Y.
    They were from Silverstone Modification and Racing (on the internet).
  4. #4 Re: Stainless brake hoses
    Waynesboro, PA
    I link would have been easier, and I am guessing you got them off of eBay. Tell them that they do not work properly and get it sorted out.
  5. #5 Re: Stainless brake hoses
    Jersey
    Go with Goodridge or oem rubber ones. I already switched back to rubber ones on the rear brakes, zzp's "newer improved ones" failed. I will be putting my front ones back to oem lines in the spring.
    16' wrx sti- stock
  6. #6 Re: Stainless brake hoses
    Greensburg, PA
    If you want stainless steel go with good ridge. Performance peddler gives clubgp members a discount but if your not just type in glubgp and i think it come out to like 90.
    Heres one rule of thumb with brake components.
    You can go as fast, blow an engine and still be fine because you can stop....l
    Instead you can go fast, blow a brake line and crash because you couldn't stop!!!
    Just remember that. Ive blow 2 ZZP rear lines luckily I was at a stop both times. supposedly they just got new and improved lines but I wouldn't test them.
    Goodridge lines are what you want if you go with SS lines. There proven lines.
    Mods:3.4 pulley + recommended mods/ F-Body Front & rear GXP Calipers/ GMPP handling upgrade kit + otto strut brace/ SSC Gen 1 Springs on GR-2 struts/ Verde 5 18x8 Rims
  1. Making AN hoses
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2009, 10:56 PM
  2. Hoses VS Belts.
    By GTPRiley in forum The Rant Forum
    Last Post: 01-05-2009, 05:44 PM
  3. ZZP's 5th Stainless Brake Line!!
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 06:06 PM
  4. Stainless steel brake hoses
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2008, 06:18 PM
