Thread: No hope left
Results 1 to 9 of 9
  1. #1 No hope left
    Sep 2016
    Johnson city
    Hello everyone,
    I have a 04 CompG that randomly developed brake issues a few months ago...4 new rotors, 4 complete front and back sets of pads, brake hoses on all 4 corners, 4 new calipers on all corners, and a new master cylinder and my brake issue has come full circle. They make grinding noises even when wet. No visible gouging on any rotor, front or back. And when they are cold they make high frequency squeaking when backing up. They sound absolutely horrible. And I'm out of ideas aside from replacing everything again. Anyone have any ideas?
  2. #2 Re: No hope left
    St. Louis
    Check your parking brake. Could be dragging on the rear rotors.
    Also, are you sure it's brake related? Could be a wheel bearing too.
  3. #3 Re: No hope left
    Sep 2016
    Johnson city
    The parking brake cable isnt even connected to the rear calipers. It seized years ago since the previous owner never used it. and both hubs are good.
  4. #4 Re: No hope left
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by drhans View Post
    They make grinding noises even when wet. ideas?
    grinding when braking only? all 4 corners doin it?
    what are the random brake issues you were experiencing?
    08 grand prix NA3800
  5. #5 Re: No hope left
    if you live in a area with snow and got the car buried or just plowed through some deep snow. all of the dust shields might be touching the rotors. happened to my regal.
    or they may have gotten bent over some other way, worth a check tho.
  6. #6 Re: No hope left
    Sep 2016
    Johnson city
    Doesn't snow often. And dust shields are perfect somehow. Rear is where the main issue seems to be. The front passenger side seems to drag a bit when you first move it be then it clears up. The rear are actually starting to grove the rotors which is just sad considering the they arent even 3 months old.
  7. #7 Re: No hope left
    the rubber hoses could be shot. they stop letting line pressure flow back off the calipers.
  8. #8 Re: No hope left
    Sep 2016
    Johnson city
    all 4 hoses were replaced when the calipers were replaced. During that we also replaced the master cylinder.
  9. #9 Re: No hope left
    e brake just came to me, the e brake can hang up on the 04 up models.
  1. i hope somebody can help me
    By g9t7p in forum General Tech Discussion
    Last Post: 03-07-2012, 09:45 AM
  2. hope this isn't a repost..
    By Myprixxx in forum Off Topic Discussion
    Last Post: 03-08-2010, 09:38 PM
  3. I sure hope I'm in the right section for this
    By sarahleigh112 in forum Brakes/Suspension/Chassis
    Last Post: 12-17-2009, 02:21 AM
  4. :( no hope
    By LogicGTP in forum Track Sessions and Kills
    Last Post: 02-18-2009, 04:52 PM
  5. funny ( i hope)
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 10-02-2008, 08:13 PM
