Thread: Traction and brake light still on after replacing wheel bearing
Results 1 to 4 of 4
  1. #1 Traction and brake light still on after replacing wheel bearing
    Jan 2022
    Shelby
    The wires were ripped from the front passenger side wheel bearing for the ABS sensor somehow. So both lights were on on the dash. I bought a new wheel bearing a cheap one off of Amazon, and put it on and the lights went out but when I put the car in gear and start to drive the lights come right back on. The TC button works until the lights come on you can turn the traction control on and off to the point where the lights come on and it doesn't do anything. This is in a 2004 Comp G. Thanks for your help
  2. #2 Re: Traction and brake light still on after replacing wheel bearing
    St. Louis
    Check the body harness that plugs into the hub. Lot of times they get corrosion in the plug end that connects to the hub and even further up into the wiring.
  3. #3 Re: Traction and brake light still on after replacing wheel bearing
    Jan 2022
    Shelby
    I was going to cut that plugs off and just hardwire the wires together to rule that out.
  4. #4 Re: Traction and brake light still on after replacing wheel bearing
    Jun 2022
    San Diego
    Any luck with this issue? I'm having the same problem
  1. Replies: 14
    Last Post: 07-15-2017, 08:01 PM
  2. Replacing wheel bearing/hub for the average DIY'er?
    By SpringfieldGT in forum General Tech Discussion
    Last Post: 08-10-2014, 12:00 PM
  3. Did my wheel bearing/hub got messed up?? after removing and replacing
    By Haulero in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 03:25 PM
  4. Replacing Wheel Bearing
    By Pure2sin in forum How To Write-Ups/Tech Tips
    Last Post: 10-24-2011, 03:56 PM
  5. Replacing wheel bearing
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2008, 03:51 AM
