Thread: Which lowering springs to get in 2021?
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: Which lowering springs to get in 2021?
    SE Level Member dirtyape's Avatar
    Dec 2014
    Lomita,Ca
    i have had my car lowered for 21 yrs with orig dog bones. what do shortened ones do for you?
  2. #22 Re: Which lowering springs to get in 2021?
    St. Louis
    Quote Originally Posted by njgp View Post
    It's $599 and it includes everything you need no?
    Just want to make sure I'm not missing something because I'm looking at purchasing these and don't think there is anything additional required (other than the recommended shorter dog bones).
    Info from Bio on lowering:
    a) those are overpriced. get them off a pontiac montana minivan from a junkyard, that's what those are. $5.
    b) 1" shorter is too short, you want about 3/4" shorter. get a stock set and cut them down with a new hole that you drill. $free.
    Me personally, when I lowered my car on Eibachs I corrected this with mount spacers. You can make them and install them yourself. Search "Vinnie spacers" on here and you should find how to make them. They go on the top and bottom of your engine and trans. mounts to correct the geometry of lowering which can cause vibrations and excess wear on the axles. I'm still running stock length dogbones.
  1. What needs done to remove Lowering Springs and go back to stock springs?
    By NotEnoughGPs in forum Brakes/Suspension/Chassis
    Last Post: 05-19-2015, 09:49 PM
  2. Lowering springs
    By twitticus in forum Introductions/Noob Questions
    Last Post: 09-19-2014, 03:19 PM
  3. lowering springs?
    By bandits grand prix in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2011, 08:09 AM
  4. lowering springs?
    By Hawkins04 in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2010, 01:03 PM
