Thread: Question for folks with SLP springs
Results 1 to 6 of 6
  1. #1 Question for folks with SLP springs
    SE Level Member ThatOldCarSmell's Avatar
    Apr 2020
    Upstate SC
    Curious if GR2's would be sufficient for SLP springs, as they are reputed to not drop the car too much. I ran across a set of SLP's that were purchased new and never installed, and for $100 shipped, I'm inclined to get them. I know AGX's are adjustable, better, etc, but I want to know if the SLPs will blow out GR2's in short order like some of the lower springs will. Also, not overly interested in coilovers, as I would likely never use the adjust-ability of them, and have heard mixed reviews of BC's on other vehicles. Thanks to anyone with input!
    99 GTP:
    ZZP FWI , ZZP 3" catted DP, Resonator delete,The occasional Poly bushing, ZZP front sway Bar, NGK TR6's, LED Headlights, 180* TStat, Anti- pogo washers ...This list seemed a lot longer before I started typing....
  2. #2 Re: Question for folks with SLP springs
    I ran the KYB struts on SSC lowering springs with no problems at all.
    Those springs won't do any worse.
  3. Thanks ThatOldCarSmell thanked for this post
  4. #3 Re: Question for folks with SLP springs
    Apr 2020
    Upstate SC
    Thanks man. are the SSC's the ones that were made by vogtland, or were those the GMPPs?
    99 GTP:
  5. #4 Re: Question for folks with SLP springs
    I'm not sure.
    The SSC springs are the same ones bought through Canuck Motorsports but I'm not sure they still sell them.
  6. #5 Re: Question for folks with SLP springs
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by ThatOldCarSmell View Post
    No they are not.
  7. #6 Re: Question for folks with SLP springs
    Nov 2012
    Madison
    I bought a new set of SSCs a year ago.
    My old set were a little bit too rusty.
    If you use SSC, buy some sized vinyl tubing to cut and wrap around the high and low areas.
    The compression of car weight will have the coils touch and bind after awhile.
    Mine popped pretty good until I did this on the first set. A real ***** when on car.
    Much easier to do when new.
  8. Thanks ThatOldCarSmell thanked for this post
  1. Camber Bolt question for Lowering springs
    By 92builtbird in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2014, 07:44 PM
  2. bushings and springs question
    By Ryansgtp in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:52 PM
  3. Question about springs
    By scottgp34 in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2011, 08:30 PM
  4. Rocker/Springs question.
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-10-2009, 01:21 PM
  5. Rims and Lowering springs question
    By Dagujugrandprix08 in forum Tires & Wheels
    Last Post: 03-04-2009, 01:38 AM
