#1
Clunking noise from rear suspension
Hi all,
My newly acquired GTP has a clunking noise from the right rear. It doesn't do it all the time but if you hit a pothole etc on the right rear there's a clunking and banging noise.
I've done a visual inspection and the trailing arms etc have some surface rust but are solid. The swaybar end links are also still attached. I see some seeping from the lower spring perch, so I strongly suspect the strut is bad... but my question is with bad struts will it travel enough to bang something in the back? I think it might be hitting the bump stops but due to the successions of clunks/bangs it almost sounds like it's hitting something else. Is it possible with extended travel it could smack into the exhaust.
Regardless, replacing the two rear struts is going to happen. I don't see anything else back there that could make that kind of noise and figured that others here more familiar with the rear suspension setup may have some insight.
Thanks!
#2
Re: Clunking noise from rear suspension
Donating Users
07-05-2020
Hopefully it's just struts. Make sure your strut towers aren't rusted out back there.
Top Swapped 01 Imp
#3
07-05-2020
strut tower rotted out maybe? pull the trunk carpet down and you'll see for sure.
try bouncing the ass end down a few time maybe you can hear it standing still.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#4
I did bounce the rear and both sides seem to be a bit bouncy, although the left side doesn't show any obvious seeping. The right side does though. I plan to lift the car so I can check wheel bearings and brakes, and while I have the wheel off I'll take a closer look at the struts.
This area is not known for a rust belt... I looked all over the car and there's no rust on the body itself. The exhaust is in bad shape and there's surface rust on things under the car, but not the gobs of flaking rust like when I used to live further north in the snow belt. I cleaned out the trunk and there's no rust in the spare tire wheel well, to give you an idea, but thanks for the tip. I'll peel back the covers today or tomorrow in the trunk to have a closer look.
#5
GTP Level Member
07-05-2020
I have the same problem.. towers are okish. Changed everything but the hub and it still does it
I decided not to care anymore lol.
Give your lateral bars a wiggle they shouldn't move
Sent from my SM-N920V using Tapatalk
#6
maybe the muffler hangars are a bit stretched and the exhaust is banging around.
Or the hooker in the trunk is trying to get out.
"Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
Post Thanks / Like - 1 Thanks, 0 Likes, 0 Dislikes
#7
a REALLY bad strut will make a banging noise. at a certain point, the shaft will become loose in the tube, and rattle around. this is after a long time of neglect though, and i've never seen it happen to a rear, only front. nevertheless, it's possible.
sway bar links would be first suspect in my eyes. visually okay can still be loose inside the ball&socket joint. if you're changing struts, change them as well.
my $.02
danf thanked for this post
#8
