Thread: rear brake line question
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: rear brake line question
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    I would say that is OK to do. Run it close to the rack-and-pinion. Just be careful not to put the line where the sub-frame might pinch it when going over some huge bump. The subframe doesn't really move but still....
    If you're still having trouble with fittings and unions, got to a junkyard, hack up some lines and take the unions/fittings off and use them on your new lines.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  2. #22 Re: rear brake line question
    Apr 2015
    Columbus, OH
    I didn't even attempt to run the pass front line like stock. That was the first one I replaced, ever. Ran it high along the top of the firewall and down to the caliper. Been good for like a year. Don't think you can melt a brake line, maybe just rubbed through from movement?
    Top Swapped 01 Imp
  3. #23 Re: rear brake line question
    i would pull the old line and make a new one. just pre bend it to match the old one. makes sure its clipped in place.
    or you can just cut the line where its been rubbed through and put a compression fitting on it. then re-secure the line.
  4. #24 Re: rear brake line question
    Oct 2019
    spring, tx
    Did gm use a bubble or double flare on this car?
  5. #25 Re: rear brake line question
    Nov 2011
    NY
    If you made your own, why'd you place it so close to the exhaust? Anyways, get more line and route it higher on the Firewall. This shouldn't be an issue.
  6. #26 Re: rear brake line question
    Oct 2019
    spring, tx
    That's exactly what I am gonna do. I just gotta figure out how I'm gonna secure it to fire wall
  7. #27 Re: rear brake line question
    Apr 2015
    Columbus, OH
    You can kinda see mine here.
    Top Swapped 01 Imp
  8. #28 Re: rear brake line question
    Oct 2019
    spring, tx
    That's how I'm gonna do mine. It's a nice easy way. By the way do ya have the 3800 series motor?
  9. #29 Re: rear brake line question
    Apr 2015
    Columbus, OH
    LS swapped. Oops, I meant Series 2 top swap. I was dreaming for a sec.
    Top Swapped 01 Imp
  10. #30 Re: rear brake line question
    Oct 2019
    spring, tx
    Ok so the grand prix uses a bubble flare but the only tool I can find is the 45 degree double flare tool. Can I use that tool to make the bubble flare?
  11. #31 Re: rear brake line question
    Apr 2015
    Columbus, OH
    https://www.amazon.com/Neiko-20657A-...e+flair&sr=8-3
    Can you rent one? I used a kit like this.
    Top Swapped 01 Imp
  12. #32 Re: rear brake line question
    Oct 2019
    spring, tx
    Nobody here rents the iso bubble flare kit. Only the double flare kit
  1. brake line blew across rear frame
    By pontiacgt500 in forum Brakes/Suspension/Chassis
    Last Post: 08-16-2016, 11:28 AM
  2. rear brake line setup on 00 GT
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 05-21-2016, 10:05 PM
  3. Question about Changing Brake Line
    By Calikid219 in forum Brakes/Suspension/Chassis
    Last Post: 09-05-2012, 09:05 PM
  4. Brake line question
    By frankjc in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2010, 07:19 PM
  5. Front to rear brake line replacement - need advice
    By bxfl in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2010, 09:56 AM
