Thread: 2005 grand prix gt sticking brake
Results 1 to 10 of 10
  1. #1 2005 grand prix gt sticking brake
    Sep 2019
    IN
    Hey guys doing some work for a friend. I changed pads,rotors,calipers on back. Wheel got hot but is not getting hot now.. but makes grinding noise wondered what it could be?
  2. #2 Re: 2005 grand prix gt sticking brake
    Apr 2014
    commerce twp,mi
    wheel bearings good?
    08 grand prix NA3800
  3. #3 Re: 2005 grand prix gt sticking brake
    Sep 2019
    IN
    They seem like it. No play and turn by hand smoothly
  4. #4 Re: 2005 grand prix gt sticking brake
    Jul 2017
    macomb mi
    most people will recommend checking to see if the dust shield is scraping on the back easy fix and worth checking but when I was in a similar position as you it turned out to be the new brake hardware was scraping against the outer cylindrical face of the rotor. the shim has to bend it out a bit if so or try different shims
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  5. #5 Re: 2005 grand prix gt sticking brake
    id check the dust shield. jack the back tire up, hand spin the tire. listen for the sound.
    if you did rotors too a lot of the time the ebrake drum is not the same as the old one and needs to be re adjusted, could be dragging and needs to be backed off. sadly you need to take the rotor off to adjust the e brake.
  6. #6 Re: 2005 grand prix gt sticking brake
    crap 05, scratch the e brake drum jazz lol but do make sure the cable is not holding the lever on the caliper.
  7. #7 Re: 2005 grand prix gt sticking brake
    Sep 2019
    IN
    E brake isn't hooked up... I'm starting to think the brake lines are collapsing... you can't flipping hear anything cause the exhaust... but she swears she hears something then it goes away.. front brakes are starting to cut into the rotors I think that's the noise plus back passenger is still sticking getting hot even though all new. So think rubber brake lines are shot after 308k.. lol
  8. #8 Re: 2005 grand prix gt sticking brake
    its either the hose or the caliper is sticking. most bad hose cases seem to be the fronts tho, the rear is a kinda short hose.
  9. #9 Re: 2005 grand prix gt sticking brake
    Sep 2019
    IN
    New caliper so I'm thinking hose
  10. #10 Re: 2005 grand prix gt sticking brake
    Apr 2015
    Columbus, OH
    Quote Originally Posted by Natcox012 View Post
    Think that's where I would start. The dust shield would be my second guess. They are only a couple mm away from the rotor and just a little rust build up on the edge of the shield will make them rub on the rotors.
    Top Swapped 01 Imp
  1. Replace rear brake pad and rotor on 2005 Grand Prix base
    By Coldwaves in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2016, 06:43 AM
  2. Replies: 184
    Last Post: 03-30-2014, 07:51 PM
  3. 2005 Grand Prix Parking Brake issue
    By Chainsaw6966 in forum Brakes/Suspension/Chassis
    Last Post: 11-08-2012, 11:29 AM
  4. 2005 Grand Prix GTP Rear Brake Issue
    By whitefeathersnpr in forum Brakes/Suspension/Chassis
    Last Post: 08-24-2012, 07:40 AM
  5. 2005 Grand Prix, rear brake frustration
    By gt2003 in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2012, 04:09 PM
