Thread: Fitting rear pad ears
Results 1 to 3 of 3
  1. #1 Fitting rear pad ears
    SE Level Member LouF's Avatar
    Oct 2011
    Ohio
    Just an FYI:
    I had to grind the ears down on both of the inside rear of DuraLast brake pads (sanded with a belt sander). Now they move as they should. Touched them with paint to cover the bare metal. They must have been a little off on their punch.
    I'm very surprised the pad wear was even (on the pad itself, and between the inner and outer).
    2005 Grand Prix GTP
  2. #2 Re: Fitting rear pad ears
    ive had to that on almost every car ive owned. i use a angle grinder tho, mush faster.
  3. #3 Re: Fitting rear pad ears
    Apr 2015
    Columbus, OH
    I've had to do the same on several cars. Seems more common on cheaper pads. I always clean up the caliper bracket as good as I can first. Never bothered painting because the paint won't cure hard before I first use the brakes. I just put a big glob of caliper grease on the ends.
    Top Swapped 01 Imp
  1. Fitting?
    By james782004 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2016, 07:36 PM
  2. Fitting an L36 HV3 into an L26
    By nik12937 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-27-2014, 08:17 PM
  3. Still wet behind the ears
    By Kimpossibly in forum Introductions/Noob Questions
    Last Post: 04-14-2013, 10:02 AM
  4. which fitting is which?????
    By chancinit666 in forum General Tech Discussion
    Last Post: 12-11-2010, 11:58 AM
  5. FPR vac fitting
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2009, 11:50 PM
