Thread: 2002 impala wheel hub replacement
Results 1 to 10 of 10
  1. #1 2002 impala wheel hub replacement
    Dec 2014
    TN
    need advice help how to replace front and rear hubs also what brands are good and i want to replace rotors and brakes also
  2. #2 Re: 2002 impala wheel hub replacement
    Youtube the repairs if you want a hands on point of view, it's been covered many times over.
    Anything that comes up as a grand prix, regal, park ave, impala, monte carlo is the same body platform and the repair is pretty much exactly the same.
    Cliff notes, remove wheel, remove caliper, remove rotor, remove axle nut for fronts, remove 3 bolts holding bearing to knock, smack it off with a hammer, replace bearing and install in reverse order.
    Axle nut torque spec is 118ft lbs, lug nuts are 100ft lbs. I use the german spec on everything else.
    Anything with a good warranty for bearings work. SKF and MOOG bearings are great buys.
  3. #3 Re: 2002 impala wheel hub replacement
    Backs are a little more fun with the ebrake adding to the enjoyment. It's straightforward though.
  4. #4 Re: 2002 impala wheel hub replacement
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    If you have ABS, be careful to not pinch the wire harness.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  5. #5 Re: 2002 impala wheel hub replacement
    Dec 2014
    TN
    ok thanks alot for your help i will begin my research also is the front ones going to be a pain im not a mechanic but
    i have a sense of know how
  6. #6 Re: 2002 impala wheel hub replacement
    Dec 2014
    TN
    ok thanks for help i wil do my research is the front ones a pain or not im never done this before im sure i could give a try
  7. #7 Re: 2002 impala wheel hub replacement
    Dec 2014
    TN
    also this fix the trac control abs light
  8. #8 Re: 2002 impala wheel hub replacement
    May 2016
    Rouge Island
    Quote Originally Posted by biglion View Post
    Get it scanned for ABS codes, it's free at Autozone. You need to know what's throwing the light to know if just hubs is gonna fix it.
  9. #9 Re: 2002 impala wheel hub replacement
    Dec 2014
    TN
    Quote Originally Posted by cheatah faheatah View Post
    ok thanks i will do
  10. #10 Re: 2002 impala wheel hub replacement
    Dec 2014
    TN
    ok thanks i went to autozone today not to long ago as im typing this and he told me he cant scan for abs just my luck lol lol
  1. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  2. FS: 2002 Chevrolet Impala (Very nice car!!) -- KC, Mo
    By Supercharged99 in forum For Sale - Vehicles
    Last Post: 05-26-2013, 05:11 PM
  3. 2002 Impala: On it's way
    By barnettimpala in forum Members Rides
    Last Post: 05-11-2013, 03:17 AM
  4. Remove Front Wheel Bearing Hub Grand Prix Impala Regal
    By 1ATony in forum How To Write-Ups/Tech Tips
    Last Post: 10-18-2011, 10:35 PM
  5. 2002 GTP replacement cat question
    By toronado97 in forum General Tech Discussion
    Last Post: 03-08-2011, 05:20 PM
