Thread: tips on removing bolts from strut
Results 1 to 7 of 7
  1. #1 tips on removing bolts from strut
    SE Level Member blakephxaz's Avatar
    Feb 2018
    Phoenix Arizona
    i am trying to swap out my rear struts on my 05 gtp but i can not get the 2 bolts out they r super stuck ive done these befor on other cars and it was not easy but these r crazy any advice on how to get them loose ive heated them up i have penetrating spray been hitting on them the just wont seem to budge any advice would be great thsnks
    2005 Pontiac grand prix gtp phx az first wbody car first time doing any mechanical work just plan new to this whole thing
  2. #2 Re: tips on removing bolts from strut
    you need to hammer them out. i leave the nut at the end a few threads and beat em out.
  3. #3 Re: tips on removing bolts from strut
    Feb 2018
    Phoenix Arizona
    yea that's what I normally do too but these ones will not come out is there any way to relieve pressure by jacking it up or droping the sturt down
  4. #4 Re: tips on removing bolts from strut
    use a larger hammer then. they are splined bolts. ive used a roofing hammer, but it take a lot more dead on hard blows to bust em out. 5 lb baby sledge works in like 3 shots.
    knowing how to swing a hammer also helps. the crap ive seen go on is amazing. cant be a shoe maker. grab that handle at the bottom and swing it.
    then again, i used to swing a hammer for 20 years 8 hrs a day. i know a thing or two about using a hammer lol
  5. #5 Re: tips on removing bolts from strut
    Oct 2017
    Las Vegas
    Try taking the strut top nuts/bolts off first. this will allow the part to move slightly and possibly get more penetrating oil moving on the bolt splines. Air Hammer works wonders! Regular hammer will work too, lol But you will probably mushroom the hell out of those bolts. Make sure you grind down the mushroomed end before you attempt to put them back.
  6. #6 Re: tips on removing bolts from strut
    Feb 2018
    Phoenix Arizona
    i finally got them out i just sparyed the entire bottle of penetrating spray between a 4 bolts and just left the nut on so i didn't mushroom the bolt and just swung the hammer at the bolt like it owed me money and they finally come loose thanks for the advice it was driving me crazy i was starting to get mad
  7. #7 Re: tips on removing bolts from strut
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by blakephxaz View Post
    Don't get mad .... Use punctuation.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  1. Removing bolts to replace wheel hub bearings
    By factory in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2014, 06:28 AM
  2. Lower strut mounting bolts-- where to buy?
    By lightheat in forum Brakes/Suspension/Chassis
    Last Post: 08-01-2010, 08:56 PM
  3. removing exhaust tips
    By Bakerdd in forum General Tech Discussion
    Last Post: 01-28-2010, 09:44 PM
  4. Tips on removing excess RTV?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-21-2008, 10:25 PM
  5. Removing collector flange bolts without breaking anything.
    By BackInBlack in forum General Tech Discussion
    Last Post: 07-25-2008, 12:31 AM
