#1
2001 Park Avenue Ultra Suspension options
Hey guys, I just recently purchased a 2001 park ave, and is there anything I can do to the suspension? Or am I kinda stuck...?
Post Thanks / Like - 1 Thanks, 0 Likes, 0 Dislikes
KShef thanked for this post
#2
Re: 2001 Park Avenue Ultra Suspension options
Turbo is the way to go.
01-04-2018
What are you after or trying to do?
I want to lower it a bit, and stiffen it up. the thing has worse body roll than my old gtp with bad struts lol
#4
01-05-2018
There were a few different suspension levels. I'm quite rusty .. I think the FE5 was the stiffest available for the PA's. Energy suspension has/had urethane bushings that could be replaced and would help as well. IIRC you have the self leveling air in the back like my Bonneville did. Might be worth looking into drag bags as they would stiffen it up. Won't lower it though.
ill have to check out the FE5, and the energy suspension bushings, thanks guys!
#6
Limited options for upgrades. Eibach used to make lowering springs for the Cadillac STS that fit but are now discontinued. I have Addco front and rear swaybars on my Ultra. They are significantly larger than stock and use poly bushings. You can buy them from Summit (lead time is 3-4 months).
Park Ave, turbo
13.1 112.9
