Thread: 05 comp g suspension upgrades
Results 1 to 8 of 8
  1. #1 05 comp g suspension upgrades
    Jul 2015
    indianapolis
    hey guys i was wondering if anyone could point me in the right direction as to upgrading the suspension on my 05 comp g, i know they should make solid sway bars, poly end links and bushings and what not. any suggestions on brands or any advice on going that route would be appreciated thanks!
  2. #2 Re: 05 comp g suspension upgrades
    GTP Level Member buickman104's Avatar
    NYC
    It depends on what you want. Many suspension set ups out there. Some will make you hate the car as ride quality will suffer greatly other set ups might leave you unsatisfied and wanting more. Others will leave you with a car that rattles your teeth at idle. Either way it will never handle like a lighter FWD car or a RWD car with a modern suspension, but it will handle remarkably better than stock. Can you tell us what you are looking for?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: 05 comp g suspension upgrades
    GTP Level Member
    Jun 2016
    Cleveland ohio
    If you have the Comp G front sway bar switch it to the 06+ solid sway bar. You will need control arms with it. I had police control arms and rebuilt mine with the solid moog control arm horizontal bushing and the new Moog socket type vertical bushing. This made a Great improvement in cornering and nose dive. Rear solid stabilizer bar and or solid bushings. Front and rear strut tower braces help a bunch. Solid engine lower, upper dogbone and transmission mounts. Replace the rear trailing arms with at least the boxed type. I have the ZZP cro-moly ones and they are good. I also have the Ingall lateral links installed.
    As of struts I tried KYB and they suck. I switched back to New OE stock FE3 struts and springs front and rear and they were much better!
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  4. #4 Re: 05 comp g suspension upgrades
    NYC
    Agreed about the KYB struts sucking. They failed in less than a year in my lowered GTP.
  5. #5 Re: 05 comp g suspension upgrades
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Quote Originally Posted by buickman104 View Post
    Same here and I wasn't even lowered! In less than a year It felt like i had 300k miles on them. I took them off to test the rebound and 2 of them were completely wasted. I could pull up and down the piston. A third would not come back up after pushed down. The forth was good but not as strong as it should have been.
  6. #6 Re: 05 comp g suspension upgrades
    NYC
    On a side note is are KYB struts for Japanese cars better than the crap they produce for w bodies?
  7. #7 Re: 05 comp g suspension upgrades
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    I priced and stock FE3 from Rockauto with springs and just front mounts is only like $300 less than BC coilovers.
    Solid mounts I say go ahead if you want. I see little, if any, performance benefit. However, if you feel your teeth fit too tightly together, it's a possible solution.
  8. Likes WarStryker13 liked this post
  9. #8 Re: 05 comp g suspension upgrades
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    I have no explanation for why, but the KYBs I shoved under mine still feel brand new with SSC lowering springs after ~1.5k... Jury is still out on whether they hold up, but they're not doing bad so far.
    Maybe the cold preserved them somehow? lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  1. suspension upgrades for 04+ GPs
    By gxp revenge in forum Brakes/Suspension/Chassis
    Last Post: 06-03-2014, 09:05 PM
  2. 04+ GP suspension upgrades?
    By painthorsemoe in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2014, 11:50 AM
  3. Need Suspension upgrades
    By Luda in forum Brakes/Suspension/Chassis
    Last Post: 04-15-2010, 09:17 PM
  4. 1995 GP suspension upgrades?
    By mikefeelsgood in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2009, 04:50 PM
  5. I can't find suspension upgrades for my 04 GT
    By Lionel in forum Brakes/Suspension/Chassis
    Last Post: 08-07-2009, 05:06 PM
