#1
05 comp g suspension upgrades
hey guys i was wondering if anyone could point me in the right direction as to upgrading the suspension on my 05 comp g, i know they should make solid sway bars, poly end links and bushings and what not. any suggestions on brands or any advice on going that route would be appreciated thanks!
#2
Re: 05 comp g suspension upgrades
GTP Level Member
11-21-2017
It depends on what you want. Many suspension set ups out there. Some will make you hate the car as ride quality will suffer greatly other set ups might leave you unsatisfied and wanting more. Others will leave you with a car that rattles your teeth at idle. Either way it will never handle like a lighter FWD car or a RWD car with a modern suspension, but it will handle remarkably better than stock. Can you tell us what you are looking for?
2000 Bronze Metallic GTP
Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
#3
GTP Level Member
11-22-2017
If you have the Comp G front sway bar switch it to the 06+ solid sway bar. You will need control arms with it. I had police control arms and rebuilt mine with the solid moog control arm horizontal bushing and the new Moog socket type vertical bushing. This made a Great improvement in cornering and nose dive. Rear solid stabilizer bar and or solid bushings. Front and rear strut tower braces help a bunch. Solid engine lower, upper dogbone and transmission mounts. Replace the rear trailing arms with at least the boxed type. I have the ZZP cro-moly ones and they are good. I also have the Ingall lateral links installed.
As of struts I tried KYB and they suck. I switched back to New OE stock FE3 struts and springs front and rear and they were much better!
2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
#4
GTP Level Member
11-22-2017
Agreed about the KYB struts sucking. They failed in less than a year in my lowered GTP.
#5
GTP Level Member
11-22-2017
buickman104
Same here and I wasn't even lowered! In less than a year It felt like i had 300k miles on them. I took them off to test the rebound and 2 of them were completely wasted. I could pull up and down the piston. A third would not come back up after pushed down. The forth was good but not as strong as it should have been.
#6
GTP Level Member
11-23-2017
On a side note is are KYB struts for Japanese cars better than the crap they produce for w bodies?
#7
I can't car too good.
12-30-2017
I priced and stock FE3 from Rockauto with springs and just front mounts is only like $300 less than BC coilovers.
Solid mounts I say go ahead if you want. I see little, if any, performance benefit. However, if you feel your teeth fit too tightly together, it's a possible solution.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#8
I break things.
12-30-2017
I have no explanation for why, but the KYBs I shoved under mine still feel brand new with SSC lowering springs after ~1.5k... Jury is still out on whether they hold up, but they're not doing bad so far.
Maybe the cold preserved them somehow? lol
04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
87 Dodge Ram 50: Junkyard rescue, resurrection in progress.
