Ok, so I've had this issue going on for a bit, not sure what it is. Sounds like my tire is rubbing going less then 5mph, or turning in parking lots at low speeds. I've replaced both LCA, upgraded Sway Bar with moog frame bushings and end links, new outer tie rods. Cv axle on drivers side as well. I'm also getting a creeking sound when turning both ways as well as the tire rubbing sound, there is no plastic rubbing in the inside of the tire. I'm not sure what either noise could be. Any ideas? 131k
