Thread: Odd Behavior
Results 1 to 7 of 7
  1. #1 Odd Behavior
    Aug 2016
    CT/RI Border
    2007 GXP OEM Calipers and Rotors not sure on Pads
    So I've noticed in some weather conditions, extreme cold or amounts of precipitation my break pedal gets heavier. Fluid levels are consistent during all usages, pads are still healthy, rotors appear to still be flat with good thickness. Is there something in the ABS/Stabilitrac that causes this?
    I do mean noticeably heavier, on dry/warm conditions its light 'til approximately 1/4 press, on wet/cold its essentially instantaneous.
    Sent from my ASUS_Z00TD using Tapatalk
  2. #2 Re: Odd Behavior
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Ever bleed out all the old fluid? Brake fluid takes in moisture after a while.
  3. #3 Re: Odd Behavior
    Mar 2017
    Internet
    If you are saying your brakes work much better in cold/wet you are not alone.
    I am running R1 Concepts premium rotors with stop tech ceramic pads. The difference in pedal is amazing cold and wet vs dry or warm. Scottydoggs and I were chatting about this one day as he see's the same behavior on his setup which I think he said was R1 eline rotors and stop tech pads.
  4. #4 Re: Odd Behavior
    r1 eline with r1 scorched ceramic pads.........yup pedal is very touchy when cold.
  5. #5 Re: Odd Behavior
    Aug 2016
    CT/RI Border
    Yes I did mean it worked better cold/wet. I understand heat makes brake performance suffer, it just seems so much more extreme to me than I am used to.
    I do not know what pads it has as they haven't needed changing yet and I bought the car with them already on. I need to do half shafts soon so I might look at changing them then.
  6. #6 Re: Odd Behavior
    Mar 2017
    Internet
    Scott and I just joke about it. I'm in an A6 and the braking when warm/dry is pretty amazing. Add cold/wet and you'd better be careful or you might dash plant yourself lol
  7. #7 Re: Odd Behavior
    Dec 2013
    Enfield
    Quote Originally Posted by BillBooost37 View Post
    Or dash plant your passenger when they don't expect it
  1. Wideband behavior
    By 2004l67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2016, 09:33 AM
  2. Alternator behavior on their way out
    By Beelzeboul in forum General Tech Discussion
    Last Post: 08-30-2012, 12:06 AM
  3. Very weird engine temperature behavior...
    By T0pwater in forum General Tech Discussion
    Last Post: 04-13-2011, 01:44 PM
  4. Erratic Boost and other odd behavior
    By tpboyce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2010, 09:54 PM
