Thread: steering rack upgrades
Results 1 to 14 of 14
  1. #1 steering rack upgrades
    hangover park IL
    the turbo regal is an FE3 rpo 00 regal GS
    steering rack is 2.5 lock to lock
    we just upgraded it to the GXP/CompG rack (04-06) and it is 2.25 turns lock to lock
    figured id post this for others
    ~James~ Psychotic Gearhead
  2. #2 Re: steering rack upgrades
    Buffalo
    Whaaat? That's awesome. Direct fit or a custom "turbocharged400sbc" fit?
  3. #3 Re: steering rack upgrades
    hangover park IL
    Bolt in
  4. #4 Re: steering rack upgrades
    GTP Level Member buickman104's Avatar
    NYC
    Same connector for the magnasteer pig tail as a 2000 GTP? :P
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: steering rack upgrades
    hangover park IL
    Yeah....cheaper for GM
  6. #6 Re: steering rack upgrades
    Buffalo
    Solid advice man. Thanks !
  7. #7 Re: steering rack upgrades
    Banned
    GM part or parts store?
  8. #8 Re: steering rack upgrades
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    According to what I can find out, the total end-to-end length of the rack in both the '00 Regal and '04 GTP is 49.75", while my '02 GTP is showing 48.75", so doesn't look like it will fit for me. Seems to me they would all be the same, GM is known for re-using parts out of the corporate parts bin.
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  9. #9 Re: steering rack upgrades
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Is there less turning of the wheel because the GXP rack is stronger? Does it maybe provide more hydraulic pressure because it comes from a heavier vehicle? We all know the stock racks are garbage. I wonder how much more durable a GXP rack would be.
    I will be doing the rack on my 2000 GTP in the next week or so. I was thinking if I buy the GXP rack on RockAuto, and then ship back my GTP core, will they give me a hard time and say I'm pulling shenanigans? Resulting in me loosing $100. Maybe this is something I can pull off easier at a store at the counter.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  10. #10 Re: steering rack upgrades
    if you know what makes a rack work, you'd know its just a different gear ratio used. cant see this .25 of a turn helping much really.
    back in the day if you swapped a quick ratio steering box you went from like 5 turns or so to 3.0 ish lock to lock, you had a noticeable difference.
  11. #11 Re: steering rack upgrades
    hangover park IL
    Quote Originally Posted by Burbman View Post
    they should be the same the only vehicle I could see having a different rack would be the G & H bodies and those have completely different mounts for the rack.
    Double check the part number for the inner and outer tie rod ends and they all seem to cross to the same for me
  12. #12 Re: steering rack upgrades
    GXP Level Member suitercrew's Avatar
    Oct 2015
    I really want to figure out if this is workable for the 97-03 s!
    Sent from my LG-H901 using Tapatalk
  13. #13 Re: steering rack upgrades
    GTP Level Member
    Jun 2016
    Cleveland ohio
    ...... does this mean that I can take my 04 comp g magnasteer rack and put in my 07 non magnasteer plug it in and it will work?
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  14. #14 Re: steering rack upgrades
    Oct 2015
    Quote Originally Posted by rickisrad View Post
    I'm not an expert but from what I have heard on here it should work l, minus obviously you wont have magnasteer.
    Sent from my LG-H918 using Tapatalk
  1. P-steering rack rebuild
    By GreyElf in forum General Tech Discussion
    Last Post: 10-15-2015, 08:01 PM
  2. Steering Rack
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 07-20-2015, 07:03 AM
  3. How can you tell steering rack bad?
    By timboku in forum Brakes/Suspension/Chassis
    Last Post: 03-31-2014, 12:14 AM
  4. Steering rack
    By 98ctd in forum Brakes/Suspension/Chassis
    Last Post: 01-21-2014, 10:59 AM
  5. steering rack
    By GTP Ryan in forum General Tech Discussion
    Last Post: 11-22-2010, 04:04 PM
