Thread: Traction control turns on when entering and leaving parking spaces
Results 1 to 7 of 7
  1. #1 Traction control turns on when entering and leaving parking spaces
    Dec 2011
    Okc
    No lights are on my dash, but my traction control engages and makes noise when going extremely slow and trying to maneuver in and out of tight parking spaces (briefly shows up on DIC). No codes, no lights, and works perfectly all other times.
    Any suggestions why it does this?
  2. #2 Re: Traction control turns on when entering and leaving parking spaces
    sounds like a bad ebcm .
  3. #3 Re: Traction control turns on when entering and leaving parking spaces
    Jan 2017
    xx
    Scan the car with an ABS scantool and see if you're getting an intermittent reading from one of the wheel speed sensors (almost guaranteed to be one of the front ones). Probably a pinched/damaged ABS wire somewhere in the front.
  4. #4 Re: Traction control turns on when entering and leaving parking spaces
    Jul 2010
    Coquitlam,BC,Canada
    Sounds a wiring issue in its early stages. Let it be and the light might start coming on more frequently. No harm in leaving it; you just won't have ABS or TRAC.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Traction control turns on when entering and leaving parking spaces
    Dec 2011
    Okc
    I have checked ABS codes in the past and nothing showed up. No ABS/Traction lights have ever shown up on the gauges, just on the DIC when it occurs. Traction control and ABS still work as normal.... just have the issue during tight turns at slow speeds trying to get in parking spaces.
    I think I had this issues years ago, and it went away after I replaced a hub bearing.
    I'll keep an eye on it and keep scanning!
  6. #6 Re: Traction control turns on when entering and leaving parking spaces
    Dec 2011
    Okc
    Just wanted to document that I put new struts on a few months ago.... and haven't had this problem since.
  7. #7 Re: Traction control turns on when entering and leaving parking spaces
    Nov 2012
    Madison
    so replacing struts help solve ABS/traction control issues?
    There must be a magic spell and fairy dust involved.
    But if that works, Mach 10 brother
  1. Replies: 2
    Last Post: 05-11-2016, 12:58 PM
  2. Converting turns/parking to fogs on 08 grand Prix
    By bigpsyc in forum General Grand Prix Discussion
    Last Post: 07-27-2015, 06:33 PM
  3. Traction control light only traction control
    By ccoimbre in forum General Grand Prix Discussion
    Last Post: 02-09-2014, 01:02 PM
  4. ABS and Traction Control not working but no ABS or Traction Control lights
    By jruether11 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2013, 04:40 AM
  5. Spotted white 4 door leaving UTI parking lot
    By 99prixgt in forum Northeast
    Last Post: 03-28-2009, 11:37 PM
