Hey guys my rack and pinion is leaking and feels sloppy. Also because of it leaking at one point in time I ran the resevoir dry and now my pump makes a whining noise. So I'm planning on replacing the rack and pump. My dad also recommended I replace the lines just in case there were metal fragments or anything from the pump being ran with no fluid in it. My question is how hard would this job be for a average backyard mechanic with only a Jack and jackstands. I have seen and read the how tos and it seems like an easy job if you have a lift but with only a Jack it seems like quite a b*tch. Also I'm looking at the ac Delco remanufactured parts as the parts I will be using. Does anyone recommend these parts or is there a different brand I should look at buying? Thank you!!
Sent from my LG-H901 using Tapatalk
