Thread: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
Results 1 to 11 of 11
  1. #1 Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Title says most of it, any ideas? Here is more info.
    1) Brake pads replaced 2x. Rotors replaced once.
    2) After about a month the rear, passenger side brakes start squeaking.
    3) upon inspection, one of the pads is wearing down sideways (along the length of the pad).
    4) It is the pad touching the piston.
    2006 Grand Prix GXP
  2. #2 Re: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    bent caliper would be my guess. both pads wearing angled? or what one? is angled?
  3. #3 Re: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    I'd be looking into the bracket and slides.
  4. #4 Re: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    Nov 2012
    Madison
    Probably wrong kind of grease on the caliper pins.
    The one with the rubber sleeve is no doubt swelled and stuck.
    I just tossed one last week when doing my strut mounts in the rear
    Silicone with ptfe doesn't break down rubber
  5. #5 Re: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    Jul 2008
    New York
    Only 1 pad is wearing our on an angle, and that is the inside one. The one touching the piston.
    For something bent?
    Quote Originally Posted by spazzz View Post
    If one of the caliper pins was stuck, wouldn't either the left/right side be wearing down fast rather than top/bottom? And if that is it, you are saying a new boot would solve it?
    In general what should my next steps be? Replace the boots, grease up the pins and try again?
    Links to the pictures:
    http://imgur.com/CtG5XoQ
    http://imgur.com/0eV3Iq0
    http://imgur.com/R6Cyxs4
    2006 Grand Prix GXP
  6. #6 Re: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    take the caliper off, then the two bolts with the boot that holds the caliper on, clean them both and the holes they live in with brake cleaner then grease them both and work them in and out of the caliper till they slide like butter, add more grease if need be. then bolt it back together.
  7. #7 Re: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    Sep 2015
    Cheyenne, WY
    Looking at those pictures it looks as though the piston is cocked in the bore.
  8. #8 Re: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Does the parking brake seize on that year? That'll cook a caliper too. I'd have to agree that something about the seal around the piston makes it look suspect.
  9. #9 Re: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    Nov 2012
    Madison
    Well I was on another planer back there.
    That piston does look jacked, Sauk might be onto something
    Oreillys has a rebuild kit for 6.99.
    My bro bought some powerstop rears and one side leaked. I had to get an Oreillys rebuild kit for it. Was really simple.
  10. #10 Re: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    Nov 2012
    Madison
  11. #11 Re: Rear brake pad wearing down on an angle - 2006 Grand Prix GXP
    Jul 2010
    Coquitlam,BC,Canada
    I had the same thing last year. One of the caliper slides was sticking.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Will 97-03 Brake pads fit a 2006 grand prix GT
    By cameron92 in forum 04+ Specifics
    Last Post: 05-03-2014, 12:34 PM
  2. 2006 gp gxp right rear brake noise
    By bigtee in forum Brakes/Suspension/Chassis
    Last Post: 08-29-2012, 03:07 PM
  3. Replies: 3
    Last Post: 06-07-2012, 05:22 AM
  4. 06 Grand Prix rear brake help needed
    By Adam Taylor in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2012, 10:53 AM
