Thread: Lower Control Arm, Is This The Correct PN?
Results 1 to 10 of 10
  1. #1 Lower Control Arm, Is This The Correct PN?
    Apr 2014
    Utah
    Just bought an 04 comp G and the LCAs are terrible, super bad. Rockauto has Moog LCAs for "R-Series", part numbers RK620675 and RK620676. Are these the correct LCAs for this car? Thanks for the help.
  2. #2 Re: Lower Control Arm, Is This The Correct PN?
    Nov 2012
    Madison
    Yep.
    I have the CK620675 and CK620675.
    Tighten them tight when you do them, crank the piss out of them, use a cheater bar and a 21mm long box wrench to squeeze em tight.
  3. #3 Re: Lower Control Arm, Is This The Correct PN?
    GTP Level Member buickman104's Avatar
    NYC
    R series are their budget R(icer) series. I've gone with cheap control arms before and they went bad after one year. Unless you like doing the same work twice go for a quality model and avoid the cheap crap. You get what you pay for.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: Lower Control Arm, Is This The Correct PN?
    Apr 2014
    Utah
    Can you substantiate your suggestion with brand/part number?
  5. #5 Re: Lower Control Arm, Is This The Correct PN?
    SWPA
    04-05 (and some early 06's) have a different LCA than 97-03 and later 06-08's. You could still technically put the other LCA's on your car, you will just have an extra tab for a sway bar mount.
    Most people around here run Dorman LCA's. You can get them for around $50 a piece on Rock Auto.
  6. #6 Re: Lower Control Arm, Is This The Correct PN?
    Nov 2012
    Madison
    I stepped up your part number to the CK series then cut the tab off with a sawzall.
    I have the same year comp g
  7. #7 Re: Lower Control Arm, Is This The Correct PN?
    New York
    If you can get the dorman LCA police/Taxi for the 04 Chevy Impala, I would get them, if they will fit. I use the 01 Chevy Impala Police/Taxi LCA on my 01 GP. I also use the 01 Impala Police/Taxi Struts at all 4 wheels which are superior to the OEM Delco struts and the KYB's which are junk....
  8. #8 Re: Lower Control Arm, Is This The Correct PN?
    Quincy, Mass
    Control arms for the w bodies are all the same.
    No more GP 04 Impala SS Indy:
  9. #9 Re: Lower Control Arm, Is This The Correct PN?
    Apr 2014
    Utah
    Not ideal, but i ordered the base Moog LCAs and also those Moog ball joint style front bushings, and the Moog hard rubber (blue) rear bushings. Hope this will all go together and work.
  10. #10 Re: Lower Control Arm, Is This The Correct PN?
    Dec 2012
    Canada
    Has anyone used LCA part numbers 22947665 / 22947666 on a 97 - 03 Grand Prix, do they fit and is there a noticeable difference?
    2002 - GTP, KN-CAI, Autolite 104, Magnaflow CatBack, ZZP 3" DP, ZZP-Plog, Overkill Tune, ZZP MPS 3.6" pulley, Don Rome STB, Mobil 1 Syn, Transgo Shift Kit, Flipped Dogs.
  1. 04 gtp lower control arm
    By 310toumad in forum Brakes/Suspension/Chassis
    Last Post: 11-09-2015, 11:41 PM
  2. Lower Control Arm or just lower ball joint
    By veener79 in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2014, 01:14 PM
  3. 97-03 vs 04+ lower control arms
    By Wicked13 in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2010, 10:17 PM
  4. Lower Control Arm Replacement LCA
    By Sykkel in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 05:19 PM
