Got everything installed today minus a part when I go over a bump can still hear a rattling noise in the front and rear
PARTS INSTALLED
- Struts
- Control Arms
- Inner And Outter Tie Rods
- Sway Bar Link Kit
- Sway Bar Bushing
- CV Joint Axle ( Might Not Need To Get Installed )
Rear
- Struts
- Sway Bar Link Kit
- Sway Bar Bushing
Thinking About Replacing ???
- Lateral Link
- Trailing Arm
I had a rattle f&r in my 06 GP, it was a rusted/loose park brake cable r/r. When it hit a bump you could hear it slap in the rear & the rest of the cable going forward would wiggle and make noise against its brackets....
For the record : I am NOT a naked meth-head who shoves rocks up my butt.
GTP Level Member
08-03-2016
Mine was sway bar links.
Still trying to figure it out I got new sway bar links installed
08-03-2016
exhaust checked over yet?
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
got new trailing arms and looked over cant figure out that rattle noise in the rear when I go over bumps
08-05-2016
I had a rattle that I fixed last week, ended up being the flex plate bolts were loose.
did it sound like it was coming from the rear of the car ??
08-05-2016
gordster1122
not really
I'd double check the rear end links. I had just replaced mine with Moog and one went bad quickly. I was going through the same thing you were until i jacked it up and shook things. Ended up being the end link that had less than 2k miles on it.
Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
Hope not just got the rear link kit installed the other day its going in for a wheel alignment tomorrow morning will get them to check it out
It would be nice if more folks followed up with what they found this is how we all learn thank you.
mrbreezeet1
Installed O'Reilly front sway bar links in the front. They went bad in a week! I had better luck with Detroit Axle links from Ebay. Lasted about a year before they went bad. Half the price too.
I don't know I just saw this have you or anyone had any luck with the Detroit Axle control arms I know some of their other parts reviews are not so favorable but the reviews on Amazon for the Detroit Axle control arms were quite favorable.
I'm just curious I already got them they seem like they're made pretty nice does anybody know how I get into my control panel to set up my notification so I get emails for these subscriptions I have?
