Thread: Front subframe mount?
Results 1 to 6 of 6
  1. #1 Front subframe mount?
    Sep 2015
    IL
    Ok, someone help me out here. Trying to check if my subframe bolts are tight. FSM says spec is 133 ft-lbs, rear ones are ok, but front looks just like a smaller flanged nut on the end of a stud? The diagram shows a solid bolt with a hex head going thru just like the rear, not a nut? I'm just a little confused about what I'm looking at. I don't wanna tighten the nut to 133 ft-lbs, seems too much for a nut that small.
    Front subframe mount? Attached Images
  2. #2 Re: Front subframe mount?
    not knowing what year car you have, ive heard theres a brace or bracket, im guessing thats it in your pic. the sub frame bolt is further up, that bar is in the way.
  3. #3 Re: Front subframe mount?
    Sep 2015
    IL
    Its an 04. I just don't see that brace mentioned in any diagrams or in the fsm under the section dealing with replacing the bushings.
  4. #4 Re: Front subframe mount?
    pretty sure its the 04 up cars with the brace bs in the way.
  5. #5 Re: Front subframe mount?
    Sep 2015
    MA
    Remove the nut and the bracket from the lower support then you can get to the front cradle bolts.
  6. #6 Re: Front subframe mount?
    Sep 2015
    IL
    Ok thanks guys
  1. subframe mount interchange
    By 91parkave in forum General Grand Prix Discussion
    Last Post: 04-26-2015, 08:19 PM
  2. WTB A2W Front Mount
    By acidcrashdburnd in forum Wanted To Buy - Parts
    Last Post: 07-22-2014, 09:33 AM
  3. Size bolt stud for FRONT control arm to subframe?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 06-01-2013, 04:19 PM
  4. Squeaking coming from front subframe area
    By 1filthygp in forum Brakes/Suspension/Chassis
    Last Post: 05-26-2013, 08:51 AM
  5. 93 grand prix front subframe bushings
    By Mike Preston in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2012, 02:38 PM
