Thread: Steering Rack Upgrade?
Results 1 to 17 of 17
  1. #1 Steering Rack Upgrade?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Well, when I was upgrading the sways on my 04 Impala, I found the source of my power steering fluid leak... rack is shot.
    Figure, if I'm going to the trouble, it'll be worth it to spend a bit more if there is an upgrade available. The current rack is "standard", no magnasteer or anything like that. I've had magnasteer before, wasn't super impressed anyway.
    Is there a police-option rack that offers different steering characteristics? Maybe another aftermarket/performance rack that offers better steering response? The leak isn't too bad, so I can keep topping off fluid and drive it for awhile yet. Gonna replace the rack and pump once I figure out the route I want to take.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Steering Rack Upgrade?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Not that I'm aware I had the same issue they are kinda junk... I went through 1 with in 6 months from the parts store the 2nd one has been good though it looks way nicer for some reason to. I changed my lines and pump too because I wanted the annoying wine to go away the new pump was as bad as the old one. I used lucas stop leak fluid it's way thicker and fixed the whine. There's not many options unless you want to spend like a 1,000 bucks for a oem rack from the dealership and I don't even know if that's any better.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  3. #3 Re: Steering Rack Upgrade?
    Knoxville, TN
    Tonkin, which brand did you go with for the P/S rack that worked? I'd prefer to do the job once.
  4. #4 Re: Steering Rack Upgrade?
    Jul 2015
    Jamestown, NY
    The one from advanced auto parts I believe its a A1 Cardone it's been a while though not sure if they changed there brands or not. You can use a coupon code online and get it cheaper if you don't know how to use the coupons let me know.
  5. #5 Re: Steering Rack Upgrade?
    GT Level Member AaroGaming's Avatar
    Jun 2015
    Detroit, MI
    I might need to do this pretty soon myself, following
    Sent from my SM-G900V using Tapatalk
    '02 GTP:​ Spectre intake, Borla cat-back, Aeroforce+boost gauges, custom pre-gen wheels, aftermarket sounds, KYB AGX w/ Vogtlands.
  6. #6 Re: Steering Rack Upgrade?
    SE Level Member brokeazfunk's Avatar
    Aug 2013
    Phoenix Az
    Just changed mine this last weekend. While your in there you might as well change the pump too. make sure you get the right hoses if you do. They will not thread in to the pump if wrong. and dont line up to the rack properly ether.
  7. #7 Re: Steering Rack Upgrade?
    Cardone rack it is, I've heard a few guys complain about them and recommend Napas brand over them but it sounds like they may of got there sh*t together and I like the fact that I can save some money through advance
    04 Comp G.
  8. #8 Re: Steering Rack Upgrade?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Rock auto carries Cardone too, uou may want to check their prices. I have bought stuff from RA where even with shipping it was substantially cheaper that Advance even with their 20% off coupon, exact same brand and part #. Not always, and cant always wait for the part, but always worth checking IMO.
    Sent from my SPH-L720 using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  9. #9 Re: Steering Rack Upgrade?
    hangover park IL
    cardone can still be hit or miss.
    i find alot of comfort in the OEM tier 1 supplier racks that you find in the junkyard on the lower mile/newer W's
    saving $ never really saves you $....when your replacing a rack for the second time when it has weak assist in one direction or a tight spot....
    ~James~ Psychotic Gearhead
  10. #10 Re: Steering Rack Upgrade?
    Dec 2008
    ****'s Creek
    Heres a 5% discount code for rick auto
    Your discount code is:
    3962992534585965
  11. #11 Re: Steering Rack Upgrade?
    Buffalo
    I've replaced mine with the Napa brand.
    no smegma steer for me. That made the steering wheel feel like it was mounted to a ship
  12. #12 Re: Steering Rack Upgrade?
    Quote Originally Posted by Turbocharged400sbc View Post
    That's true. After all I rather not have to replace it again because I wanted to save some money. There's no newer wbody in the JY atm just older crap. And IIRC they charge $100 for a rack so I'll be better off just getting a remanuf one. Looks like I settle either with a rebuilt AC delco for RA or just grab one of Napas
    04 Comp G.
  13. #13 Re: Steering Rack Upgrade?
    Knoxville, TN
    Guess it all depends on the actual manufacturer, versus the branding. For all I know, the NAPA rack could be a rebranded cardone product. Or a shared supplier. Spending more money isn't necessarily a guarantee of quality, either. If the NAPA is actually a better product, then that would be helpful. Maybe you can confirm that the NAPA rack is a higher quality product?
    Can an average joe with a standard toolbox reasonably rebuild an OEM power steering rack themself? Could buy quality repair parts, seals, etc. In my case, only problem with the rack is the pass side leaks near the tie rod inside of the bellows.
  14. #14 Re: Steering Rack Upgrade?
    hangover park IL
    when i said Tier 1 suppliers, its delphi, ac delco/delco-remy, cloyes etc. napa gold/platinum filters are napa branded WIX filters
    napa will have the oem quality stuff as well as the cheaper cardone/etc.
    thing is if you go to a gm dealer to buy a delco rack, often ive seen em resell a marked up napa part since it cheaper than going through the GM parts line. always be leary about that sorta stuff.... its why i wouldnt want to do it through the mail/shipping.
    if your rims show curb rash the bushings are likely shot, not just the seals, the bushing get hammered alot on that side due to curbing and predominance of right side potholes/suspension cycling
  15. #15 Re: Steering Rack Upgrade?
    SWPA
    I watched a video on rebuilding a rack and I can tell you its not even something I would ever consider. For the time (whereas time is money) and effort involved it would be cheaper to buy a new/reman unit. You also get a warranty and you can bolt it in as soon as you remove the old one.
  16. #16 Re: Steering Rack Upgrade?
    hangover park IL
    back in the day ed morad would have low ass mile oem units.
    moradparts.com iirc they have an ebay store but you get better deals direct.
  17. #17 Re: Steering Rack Upgrade?
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Was it hard to remove and install I have to do it this weekend or Next
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  1. Steering Rack
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 07-20-2015, 07:03 AM
  2. How can you tell steering rack bad?
    By timboku in forum Brakes/Suspension/Chassis
    Last Post: 03-31-2014, 12:14 AM
  3. Steering rack
    By 98ctd in forum Brakes/Suspension/Chassis
    Last Post: 01-21-2014, 10:59 AM
  4. question about steering rack
    By GTP Ryan in forum General Tech Discussion
    Last Post: 12-13-2010, 12:34 AM
  5. steering rack
    Last Post: 11-22-2010, 04:04 PM
