Thread: monsoon add on?
Results 1 to 9 of 9
  1. #1 monsoon add on?
    SE Level Member Morris 04 GTP's Avatar
    May 2008
    North Eastern CT
    I have an 04 gtp with a no frills single disk non monsoon radio. I want to keep it factory and I was wondering if there is a way to swap mine out for a monsoon system? what would be involved?
  2. #2 Re: monsoon add on?
    Oklahoma
    Moved to the correct area.
  3. #3 Re: monsoon add on?
    May 2008
    North Eastern CT
    really? nobody has an answer.
  4. #4 Re: monsoon add on?
    Feb 2009
    NH
    Yes it can be done. I have a NAV installed in my GT1 that is supossed to be in a GTP with monsoon. I don't have Monsoon equipment. So you should be able to add 1 but you would need to add an amp and speakers. If you don't have Monsoon, you can add any GM 04-07 Grand Prix OEM HU.
  5. #5 Re: monsoon add on?
    Feb 2009
    chicago
    i have the monsoon system in my 06 GP and you are better off with doing an upgrade with after market. i replaced my head unit with a kenwood dnx 5120 nav/dvd unit. you can get a better sound out of aftermarket. hopes this helps.
  6. #6 Re: monsoon add on?
    If you don't want to swap headunits you need to find an amp with high level inputs. You can prolly find a better amp than the stock monsoon one. I've hid some amps under the front seats on some vehicles.
    brandon
  7. #7 Re: monsoon add on?
    SE Level Member rainmkr2's Avatar
    UpState, NY
    Would be as much or more work to put in a Monsoon as to do after market. The Monsoon systems are very easily outclassed by even low end aftermarket gear. Spend your money on a good head unit and good speakers, you will be much happier in the end.
    If you are really bent on a Monsoon try Morad.
    Pontiac - RIP 2009!!
    1998 - GTP - Winter
    2006 - GXP - Sping/Fall
    1991 - TA DropTop - Summer
  8. #8 Re: monsoon add on?
    New Brunswick
    Ive put it in the 04 I had just like it would have come from factory, Needed the front and back speakers, the monsoon amp, the 6 disc headunit, center dash speaker, and the full body harness, and dash harness.
    To change the harness you pretty much have to strip everything out of the interior down to the metal.
    As others had said you can simply use an after market amp and stuff and it would not be nearly as much work involved as what i did.
    I added the monsoon along with many other things so changing the entire vehicles harness was the easiest, then i had the wiring for heads up, xm radio and everything else.
  9. #9 Re: monsoon add on?
    Pennsylvania
    If you're dead-set on the monsoon system, I'd recommend skipping the dash speaker, since you don't have a hole for it. Morad's got a Monsoon amp in stock right now. Those are like $300 new. I realize that the monsoon setup involves no thought to pair up and you could pick up the parts used from Morad cheap, but you're better off researching a bit and going after-market. The Monsoon setup is only like a half-step better than what you have, totally not worth the labor.
  1. questions about the monsoon wiring..
    By blowfishRus6 in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2010, 06:42 PM
  2. Monsoon 6 disc XM or MP3 compatible
    By ponyfool in forum Audio, Security & Visual Electronics
    Last Post: 12-11-2008, 07:44 AM
  3. Monsoon codes
    By 04 GTP COMP G in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2008, 10:55 AM
  4. Monsoon?
    By Berger in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2008, 11:29 AM
  5. 6 disc in dash monsoon
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 04-26-2008, 11:38 AM
