Thread: Figuring out replacing the monsoon amp.
Results 1 to 4 of 4
  1. #1 Figuring out replacing the monsoon amp.
    Pennsylvania
    Working with this amp: http://www.crutchfield.com/p_113KAC8...-KAC-8406.html
    Head unit is hooked up with GMOS-04.
    Im gunna split it 2 channels for the sub bridged, then 1 for each 6.5" in the doors for 4 channels total.
    The sub and door speakers I dont have any confusion with because Im running RCA's right from the head unit to the amp, then speaker wire from the amp to the sub/doors.
    Im a little unsure about how to handle the rear deck speakers, the tweeters in the doors, and the center dash speaker. I assume that all the speakers in the car get their power from the amp, so when I chop the amp out, those speakers wont get power since the new amp wont be hooked up to them. Do I need to chop up the wires connected to the factory amp and splice into them to run new wires to those speakers not powered by the new amp?
    I was also wondering about the remote amp turn on wire, can I take that from the factory amp wires, or do have to take that from the harness at the head unit?
    Sport Edition Kv5 18x8
  2. #2 Re: Figuring out replacing the monsoon amp.
    Dec 2013
    ohio
    Head unit for sure. I think it's like purple wire coming out of harness if you run power to, your factory amp will run the other speakers. There is a write up on it in the forum.
  3. #3 Re: Figuring out replacing the monsoon amp.
    Pennsylvania
    But if I cut that remote turn on wire to give the turn on signal to the new amp, won't the factory amp not turn on?
  4. #4 Re: Figuring out replacing the monsoon amp.
    Pennsylvania
    Alright, so I ran the power wire through the firewall back through the trunk, ran the RCA's from the head unit to the trunk. I disconnected the factory amp by unplugging it, and then I cut the violet "radio on" wire and spliced it onto a lead for the remote amp turn on... hooked it all up to the amp. Hooked up the sub to the amp.. the amp turns on, and the sub plays. I had the gain all the way down, but it has power and makes sound.
    Im going to cut the harness at the factory amp and splice the inputs and outputs together for the rear deck speakers and keep them stock for now.. just so they play.
    Now my last obstacle that I couldnt figure out just by looking... Im gunna be doing the doors tomorrow and I'll be running speaker wire from the amp to the doors. What's the best way to get the new speaker wires into the doors? I looked for a bit and I couldnt find an obvious opening to the rubber conduit that goes from the body to the door... any tricks?
  1. Replacing rear speakers w/monsoon and airbags
    By bjm306 in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2013, 07:53 PM
  2. Will Monsoon 6 Disk Changer function in Non-Monsoon Vehicle?
    By SlprGS in forum Audio, Security & Visual Electronics
    Last Post: 08-02-2012, 10:16 PM
  3. need help figuring this out..
    By Mikey Bonefas in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2012, 06:25 PM
  4. Replacing Monsoon System Completely Help With Head Unit
    By Ryan71695 in forum Audio, Security & Visual Electronics
    Last Post: 05-05-2012, 06:01 PM
  5. got a few problems i need help figuring out
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2011, 11:51 AM
