Thread: 0 gauge power wire
Results 1 to 20 of 31
  1. #1 0 gauge power wire
    Nov 2012
    pistolvania
    going to order some 0 gauge welding wire how long of a run will i need from alt to the trunk.i'm going to take my first trip in to the world of active going to have a jl 450/4 for the front stage 300/2 for rear fill and 500/1 for sub all ran thru a jbl ms8...kind of excited
  2. #2 Re: 0 gauge power wire
    Antioch, IL
    use a measuring tape, car is 16'long, figure out your own bends. 25' works
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: 0 gauge power wire
    Banned
    Jan 2013
    Colorado
    why are you using welding wire?
  4. #4 Re: 0 gauge power wire
    Antioch, IL
    cheaper than higher priced bull**** for the same thing is why
  5. #5 Re: 0 gauge power wire
    SE Level Member Peirce1970's Avatar
    Myrtle beach, S.C.
    Knukonceptz is pretty good wire at a reasonable price.
  6. #6 Re: 0 gauge power wire
    Arizona
    EBay
  7. #7 Re: 0 gauge power wire
    Lemme give you a heads up about wire. I know a little about a little. Do your research on quality and you'll find the welding wire is meant for brunt force power movement, not clean and easy.
    I put Knu 4 gauge in for my power wire (also my first ever install). I run a 5 channel BA amp that suggested 4 gauge as the absolute power smallest wire. Only other electrical mods are that I ensured a good ground up behind the rear seat on an existing stud that is welded to the body, 125amp factory alt and the ZZP additional cable from the alt to relay center. Power wire is connected to the battery. I have never had a bit of dimming or flicker. Knu makes quality stuff.
  8. #8 Re: 0 gauge power wire
    Sep 2014
    Worcester, MA
    stranded wire is more flexible. If you use welding wire, you might want to consider using a tubing bender to make it fit tightly and snugly.
  9. #9 Re: 0 gauge power wire
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by lance4682 View Post
    so what 4 speakers are you running up front?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  10. #10 Re: 0 gauge power wire
    Buffalo
    Ebay wire is a joke.... Yay $49 power kit ... Turns out to be absolute schit when you get it in hand. The "0" gauge wire is actuslly 4g in a super thick casing....
    I've turned away a few people with these kits in the past. Spend the $$
    0 gauge power wire Attached Images
  11. #11 Re: 0 gauge power wire
    Nov 2012
    pistolvania
    Quote Originally Posted by NebTurboST5 View Post
    http://www.sonicelectronix.com/item_...tml?show_tab=2
  12. #12 Re: 0 gauge power wire
    Buffalo
    Baller-status with the Egyptian papyrus fiber cone
  13. #13 Re: 0 gauge power wire
    It feels to me with the higher cost speakers that you want the most from the rest of the system. Please use good cables
  14. #14 Re: 0 gauge power wire
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    KnuKonceptz wire is pretty beefy, I have a 4ga amp kit in my car from them which uses copper clad aluminum cable iirc. I would recommend them.
    2012 F150 STX
    - Gonna be a race truck
  15. #15 Re: 0 gauge power wire
    Banned
    Jan 2013
    Colorado
    ricers gonna rice
  16. #16 Re: 0 gauge power wire
    Antioch, IL
    poweralbe by smetters20, on Flickr
    I have ebay 1/0ga, well bought it on ebay, not ofc though, cca. 1/0 vs oem power wire
    Untitled by smetters20, on Flickr
    Ebay brands in general suck, 1/0ga size with cheap 4ga wire inside, research first and make sure your not paying for a thick insulation jacket.
  17. #17 Re: 0 gauge power wire
    Nov 2012
    pistolvania
    so the general consensus here is to go with knuconcepts
  18. #18 Re: 0 gauge power wire
    Myrtle beach, S.C.
    4 gauge KnuKonceptz power and ground. Best bang for your buck. IMO
  19. #19 Re: 0 gauge power wire
    Arizona
    The ebay. 0 gauge i bought when stripped fit snugly in a standard 0 gauge lug
  20. #20 Re: 0 gauge power wire
    So something like this not worth it?
    http://m.ebay.com/itm/261070491084?nav=SEARCH
    04 Comp G.
  1. What Gauge Wire? How much?
    By GrandPrixGTP1 in forum Audio, Security & Visual Electronics
    Last Post: 04-07-2011, 01:31 AM
  2. How much Speaker Wire and What gauge?
    Last Post: 02-10-2011, 10:34 PM
  3. wire gauge
    By kjohnson in forum Audio, Security & Visual Electronics
    Last Post: 03-16-2010, 06:55 PM
  4. OEM wire gauge sizes
    By Toasty in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2009, 02:13 AM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
