Thread: Alpine iDA-X305s
Results 1 to 3 of 3
  1. #1 Alpine iDA-X305s
    Feb 2014
    Grand Forks, North Dakota
    Just wondering if anyone has this stereo and has had problems with the subwoofer pre-amp out RCA connection. I bought this stereo used on ebay. I hooked it up and there is signal going to my amp because the subwoofer is moving a little bit. I have the gain on my amp all the way up but it is a very weak sound for the bass notes. I know its not the amp or sub because I have a line out converter and when it is connected to that it plays just fine.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  2. #2 Re: Alpine iDA-X305s
    Ocala, FL
    I have this exact stereo (as does a friend of mine) - and no, no problems.
    Have you played with the settings on the headunit? There's a subwoofer ON, as well as a subwoofer volume control(turn it to 15 - I'm guessing this is your problem, 15/15 is basically the equivalent to being at 0)
    Of course there's also crossover settings that will really change the way things sound.
  3. #3 Re: Alpine iDA-X305s
    Feb 2014
    I did go through the settings on the stereo and made sure the subwoofer was switched to on. I had the subwoofer volume control turned up to 8 with the gain on my amp maxed out. I can't remember if I did try it at 15. I'll try again tomorrow with it up to 15 and go through the crossover settings. I guess this one is a little more complicated than the 2 din Sony touchscreen I had.
  1. Alpine X305s head unit.
    By 05BGCrystal in forum Audio, Security & Visual Electronics
    Last Post: 02-23-2013, 03:49 PM
  2. alpine.
    By BoostJunki3 in forum Audio, Security & Visual Electronics
    Last Post: 12-28-2009, 11:00 AM
  3. Alpine HU upgrade
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 06-25-2009, 07:10 AM
