Thread: My Latest Mod - Lighted cupholders
Results 41 to 60 of 71
  1. #41 Re: My Latest Mod - Lighted cupholders
    SE Level Member bradenkeith's Avatar
    Oct 2008
    SC
    I did this same thing to my prix. I took a few steps further, though I like this install, very clean, especially your button! Fantastic. I added 2 more LEDs under neath the radio in that little cubby. Not a distracting amount of glow, but just enough to give that ambiance. Here's some pics of mine:
    An overview: you can see that I have 2 in the cup holder and then 2 little ones in the cubby:
    The switch that's in the middle console:
    Light up:
    Close Up:
    The steps were quite simple: I tapped into the power from my aftermarket radio, dropped the wire behind the back, under the middle section, straight into my middle console to the switch. Then I drilled holes and installed the LEDs and ran the wire by my gear shift then put all the wires together and ran one single wire back to my switch to provide power.
    My Latest Mod - Lighted cupholders Attached Images
  2. #42 Re: My Latest Mod - Lighted cupholders
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Cool!
    What did you use to give power to the LED's?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  3. #43 Re: My Latest Mod - Lighted cupholders
    Oct 2008
    SC
    I tapped into my aftermarket radio's 12 v and ground wire. I'm about to do some cleanup of the wiring and what not, I'll take some pics of my wiring underneath once it's all said and done and post back here.
  4. #44 Re: My Latest Mod - Lighted cupholders
    Oct 2008
    SC
    Here's the pics I promised...
    The wires I dropped from the radio
    Working on the project:
    Maybe not the neatest wiring job in the world, but hey...it works!
    Different angle:
    I ended up adding 2 more LEDs to the little cubby:
    Notes: I purchased breakaway connectors for my wiring, took a couple extra steps but in the long run it'll be beneficial.
    It works like a charm! Loving it.
  5. #45 Re: My Latest Mod - Lighted cupholders
    Odessa, MO
    Quote Originally Posted by bradenkeith View Post
    I got my power from the wrapped wires that that you can see running horizontally across in this pic you posted. They are the wires for the auxillary power outlet on the passenger side of the console. Constant 12v and plenty to power a couple LEDs.
    Nice install BTW.
  6. #46 Re: My Latest Mod - Lighted cupholders
    Oct 2008
    SC
    Yeah that would have probably been easier but I felt safer with going with a wire I already spliced but that would have been a hell of a lot easier.
    Thanks! I worked hard on keeping the wired nice and clean. Took some extra time but I think it was worth it.
  7. #47 Re: My Latest Mod - Lighted cupholders
    SE Level Member grandprixgtdriver's Avatar
    Feb 2009
    Toronto
    nice.... I like it
  8. #48 Re: My Latest Mod - Lighted cupholders
    SE Level Member kassel98gt's Avatar
    Howell,MI
    nice write up
  9. #49 Re: My Latest Mod - Lighted cupholders
    Rhode Island
    Abrasive awesome job with the install very clean , unique , how about other lighting , what else have ya done ?
    See My GTP on cardomain.com/id/murph9491
  10. #50 Re: My Latest Mod - Lighted cupholders
    Odessa, MO
    Quote Originally Posted by Murph9491 View Post
    As far as lighting..... nothing. LOL
    Have to do this mod on my wife's GTP now. Going to try the multicolor slow color changing LEDs on hers.
  11. #51 Re: My Latest Mod - Lighted cupholders
    May 2008
    McHenry IL
    kool idea!
  12. #52 Re: My Latest Mod - Lighted cupholders
    ohio
    I used his idea for the cupholders and also added lights to the vents, see link below
    http://www.grandprixforums.net/f41/l...ers-18092.html
    cant see it in the pics, but the vents by the doors have lights in them too and putting the lights in the vents is super easy!!
  13. #53 Re: My Latest Mod - Lighted cupholders
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    i might do that with my alarm led , that looks nice and clean
  14. #54 Re: My Latest Mod - Lighted cupholders
    looks fast.... its slow:) beckys2000gt's Avatar
    Nov 2009
    stoystown, pa
    drink and mod always turn out pretty nice good job, looks wicked
  15. #55 Re: My Latest Mod - Lighted cupholders
    SE Level Member Nig Gtp's Avatar
    Jun 2010
    Windsor Ontario
    Wow, thats pretttty sick !
    Is that the girlfriend likes .. Then you have the Gp
  16. #56 Re: My Latest Mod - Lighted cupholders
    GTX Level Member Confusingboat's Avatar
    Minnesota
    I'm about to start a project similar, but a little more intricate. I'm replacing the bottom of the cupholders with plexiglass and adding a little plexiglass ring on top of that so it's more side-lit than botton-lit. Here's a 3D render of what it should look like:
    The top, bottom, and sides of the octagon are layered in foil tape in that render, represented by the thin gray-ish objects, and the little white-ish dots are LEDs. I'm also considering putting some sort of decal stencil on the bottom and making that bottom lit. Also split on using 8 or 4 LEDs per cupholder, but since I'm getting 200 of them I figured I might as well just throw a bunch in there.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  17. #57 Re: My Latest Mod - Lighted cupholders
    SE Level Member sonyz92's Avatar
    Alfred, New York
    i like this alot! its kinda like what the sions have, which i wish the GPs had. gonna try this on mine soon with the color changing leds
  18. #58 Re: My Latest Mod - Lighted cupholders
    Donating Users slopez's Avatar
    Dec 2010
    San Bruno
    Love em, great job simple yet brilliant
    2004 GT1
  19. #59 Re: My Latest Mod - Lighted cupholders
    SE Level Member NewBoost1997's Avatar
    Jul 2010
    Minnesota
    pretty cool mod. i was thinking about doing something like this with the "spare" LED's i have laying around...
  20. #60 Re: My Latest Mod - Lighted cupholders
    SE Level Member green18gtp's Avatar
    St.Cloud MN
    I like im thinking of doin the same just a heads up there cheaper at oznuim.com
    I dont know what I have under the hood but its tuned.
  1. Latest S2 3800 Swap FINISHED!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 07-24-2008, 02:16 AM
