whats up guys and gals ok this is my old audio setup i have 2 10" kicker cvr old model (grey and black) 4-ohm dvc
amp: **** boss 3000.1 mono block. recently purchased a new amp SSL 3000.1 1-ohm stable (pretty good amp might i add)
so everything has checked out fine sub-wiring ground power everything. WELL my problem is my system works when it wants too. I can take a quick trip to wal-mart and everything is good then when i get ready to leave no power to my amp. any suggestions
Additional info.
I have been installing audio systems for quite a while so i know how it all works.
my subs 800 watts max i have a pair so that's 1600 watts my amp 3000.1 mono block 1-ohm stable brand new out of the box terminal seals and all. so with subs are currently wired 1-ohm load at the amp. i'm not at the battery terminal with Power wire i guess that could be part of the issue other than that i'm stumped also my old amp started to do this but that amp is 5 years old (IT WAS TIME) Thanks in advance
