Thread: Aftermarket stereo
Results 1 to 15 of 15
  1. #1 Aftermarket stereo
    Feb 2014
    United States
    99 GP GTP 4 dr. Decided to go with aftermarket stereo. I would like to keep my steering wheel controls and there is 1 wire from the stereo for that. Anybody in GP land know how to hook it up to the car?
    2 hrs later: Hooked up new JVC stereo, wires seem correct, has power, no sound. Have a feeling it's related to the steering wheel controls.
  2. #2 Re: Aftermarket stereo
    Jul 2010
    Coquitlam,BC,Canada
    One option is the Axxess #ASWC steering wheel module.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Aftermarket stereo
    Feb 2014
    United States
    Thanks.
  4. #4 Re: Aftermarket stereo
    Feb 2014
    United States
    This is getting frustrating. Am I right in saying the stereo should work without the AXXESS steering wheel adapter installed? Obviously the steering wheel controls won't work. I have the Bose system and I think the trunk mounted amp is not turning on. There is a wire from the JVC stereo for this but where do I hook it into the factory car connector? Can't seem to find a decent wiring diagram on the 'net.
  5. #5 Re: Aftermarket stereo
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    You should see an AMP wire on the adaptor harness diagram. Here is a link to the pin outs for the factory harness if that helps:
    http://crutchfield.custhelp.com/app/...tail/a_id/7091
  6. #6 Re: Aftermarket stereo
    Jun 2012
    south haven mi
    12 volt .com
  7. #7 Re: Aftermarket stereo
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Aftermarket stereo
    Nov 2011
    NY
    Quote Originally Posted by Mikee View Post
    Yes, you're right, the stereo will work, but the steering wheel controls will not unless you use an aftermarket adapter. Access is a good unit and what I've used. The head unit should have a connection from the wiring to turn on/switch other units. Usually a blue wire. The corresponding amplifier should also have a point to connect this wire. The amp should only be controlled from this method as it eliminates the possibility of killing your battery. Use google, most head units and amps wiring diagrams are available online.
  9. #9 Re: Aftermarket stereo
    Feb 2014
    United States
    Finally got it all working. Thanks to all for the responses and good info.
  10. #10 Re: Aftermarket stereo
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    http://crutchfield.custhelp.com/app/...7095/related/1
    Just did my radio. found this link was very useful!
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  11. #11 Re: Aftermarket stereo
    Feb 2014
    United States
    Quote Originally Posted by QuinlanGTP View Post
    Amazing what we all know together isn't it?
  12. #12 Re: Aftermarket stereo
    Apr 2014
    Chicopee,MA
    Oh great. i found a problem. So after i have been riding around with the new radio installed i notice that when the radio and car is on. and doors open or the low gas level sound comes on it will stop power to the radio... any idea why this would happen??
  13. #13 Re: Aftermarket stereo
    Feb 2013
    Ohio
    I would double check your wiring to the harness adaptor. If you didn't use a harness adaptor.....you should have. I would guess the 12+ accessory is connected to something it shouldn't be or the ground is.
    Official GPF Red Neck
  14. #14 Re: Aftermarket stereo
    Feb 2014
    United States
    Don't know why it turns off when the low fuel light comes on. Maybe so you hear the warning "dings". That's a wild guess on my part. My stereo stays on when you turn the car off and then turns off when you open the door. Believe that's the way it's supposed to work. I guess it's for listening to the stereo with the ignition off until you get out.
  15. #15 Re: Aftermarket stereo
    Apr 2014
    Chicopee,MA
    Yeah i guess ill have to re-check wires. but im 95% sure there good. it just weird to me. never heard of this problem befor
  1. Aftermarket Stereo SWC
    By MattF in forum Audio, Security & Visual Electronics
    Last Post: 02-23-2013, 06:29 PM
  2. Aftermarket Stereo
    By gravens86 in forum Introductions/Noob Questions
    Last Post: 01-04-2013, 02:49 AM
  3. Aftermarket stereo HELP!
    By IAMABANANA MOOO in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2012, 11:47 AM
  4. Aftermarket Stereo Question
    Last Post: 09-06-2012, 02:24 PM
  5. Aftermarket Amp and Sub With Stock Stereo
    By kodeblue in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2011, 06:41 PM
