Thread: wiring diagram 97-03 stereo with bose where there few wires do?
Results 1 to 20 of 28
  1. #1 wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
  2. #2 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    ttt
  3. #3 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
  4. #4 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Quote Originally Posted by douger View Post
    that link got the main harness but this is the diagram i need the plug for
    http://i597.photobucket.com/albums/t...G_00000123.jpg
    Pink is radio on i believe
    locations of GRN, the BLU and orange/black tracer
    are all 3 heading to the amp? according to that 2nd diagram there is a dk blu for RR low audio+ and a dk GRN for LF low audio - but nowhere for a orange wire?
  5. #5 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    Quote Originally Posted by wild2crazy View Post
    If I recall, orange is almost always 12 volt positive for audio equipment.
  6. #6 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    looked up some documents from 12volt.com from alarm systems under that heading they had the pink as ignition which would work for the amp and they also had a orange/black tracer for factory disarm. The plain orange is 12volt all time which is in the larger stereo harness. and 12volts wiring diagrams for the radios are not matching the colours from the factory they need to update a little.
    shows right rear having a blu/wht when its black from factory.
  7. #7 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    i would love to know where people on here are getting the wiring schematics for the radios? theyre at least correct other than that missing 4wire into radio and its functions
  8. #8 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    they sell pig tails that plug into the factory harness, the new wires are all labeled.
  9. #9 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    yeah thats the one in my picture but thats not the factory 9 pin for the bose system . loooking at and integration harness like this one from PAC http://www.pac-audio.com/productDeta...?ProductId=168
    only harness that uses the 9 pin with the 21pin harness
  10. #10 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    I still have access to GM Service Information, so here goes:
    On your 9 pin connector, that is called connector C3 for the radio. The GM part number is 12064980
    Pin 7 - PNK - Radio on signal
    Pins 8 and 9 - Not used
    Pin 10 - LT GRN - Remote playback device right audio signal
    Pin 11 - ORG/BLK - Remote playback device left audio signal
    Pin 12 - LT BLU - Remote playback device common signal
    Pins 13-15 - Not used
    Facing the business end of the connector, pin 7 is at the right and pin 15 is at the left.
  11. #11 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Dude you are the BOMB!!!!!!!!! that's exactly what i was asking for.
    Ok how about that above picture of the 21 pin connect harness its got Black/white tracer the blue and the green.
    would those 3 that be for the steering wheel controls. and the wire GRY/black tracer in pin slot 5 of the 21pin harness.
  12. #12 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    Black Connector:
    1 DK GRN 1947 Audio Return - Left Front - Low Level
    2 TAN 511 Audio Signal - Left Front - Low Level
    3 LT GRN/WHT 1948 Audio Return - Right Front - Low Level
    4 LT GRN 512 Audio Signal - Right Front - Low Level
    5 BLK/WHT 351 Ground
    6 GRY/BLK 308 Parklamp Switch Signal - ON
    7 BRN/WHT 230 Instrument Panel Lamps Dimmer Module Output
    8 Not Used
    9 YEL 43 Fused Output - Accessory
    10 ORN 640 Fused Output - Battery
  13. #13 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Ahhh makes sense now that 9 pin connector is for the factory Cd 12disc changer that my car does not have so i'am going to assume that the other end of that 9pin connector is in the trunk tied up and was not for the factory bose system at all. good link on it here
    http://impalahq.naioa.com/HowTo/Mystery_connector.html
    Thanks again douger
  14. #14 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    Black connector:
    8 Not Used
    White connector:
    11 BLK/WHT 351 Ground
    12-13 Not Used
    14 DK BLU 1796 Steering Wheel Controls Input
    15 DK GRN 835 Entertainment And Comfort (E&C) Serial Data Communication
    16 Not Used
    17 LT BLU 115 Speaker Feed - Right Rear
    17 BLK 1946 Audio Return - Right Rear - Low Level (U85)
    18 DK BLU 46 Speaker Feed - Right Rear
    18 DK BLU 546 Audio Signal - Right Rear - Low Level (U85)
    19 YEL 116 Speaker Return - Left Rear
    19 BRN/WHT 1999 Audio Return - Left Rear - Low Level (U85)
    20 BRN 199 Speaker Feed - Left Rear
    20 BRN 599 Audio Signal - Left Rear - Low Level (U85)
    The first connector I listed appears to be for a CD changer.
    I'm pretty sure that these pinouts are at the radio end of any connector, which was driving me bat **** trying to trace the wires in your pictures.
    This is for a 99 GP.
  15. #15 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    Amp connectors
    8 pin gray:
    A BLK 351 Ground-Clean
    B YEL 116 Speaker Return - Left Rear (Tweeter)
    C DK BLU/ WHT 346 Subwoofer Speaker Feed - Left
    D DK GRN 1795 Subwoofer Speaker Feed - Right
    E LT BLU/BLK 315 Subwoofer Speaker Return - Right
    F LT GRN/BLK 1794 Subwoofer Speaker Return - Left
    G BRN 199 Speaker Feed - Left Rear (Tweeter)
    H ORN 740 Fused Output - Battery
  16. #16 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    that's the grey guy i was looking for. That saves me so much time looking.
    So lucky you got access to those gm diagrams id be on it all day looking at those.
    This info should be a sticky i bet alot of people would be needing this info later on the 97-03s
    Thanks buddy.
  17. #17 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    24 pin connector at amp:
    A1 PNK 314 Radio Signal-ON
    A2-6 Not Used
    A7 DK GRN 117 Speaker Return - Right Front
    A8 LT GRN 200 Speaker Feed - Right Front
    A9 DK BLU 46 Speaker Feed - Right Rear (Tweeter)
    A10 LT BLU 115 Speaker Return - Right Rear (Tweeter)
    A11 GRY 118 Speaker Return - Left Front
    A12 TAN 201 Speaker Feed - Left Front
    B1-3 Not Used
    B4 Bare 2012 Drain
    B5 TAN 511 Audio Signal - Left Front
    B6 LT GRN 512 Audio Signal - Right Front
    B7 BRN 599 Audio Signal - Left Rear - Low Level
    B8 DK BLU 546 Audio Signal - Right Rear - Low Level
    B9 LT GRN/WHT 1948 Audio Return - Right Front
    B10 BLK 1946 Audio Return - Right Rear - Low Level
    B11 BRN/WHT 1999 Audio Return - Left Rear - Low Level
    B12 DK GRN 1947 Audio Return - Left Front
  18. #18 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Oh you got them 100% right on Douger
  19. #19 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    Thanks buddy.
    I don't have a connector view of the steering wheel control. That's part of the serial data setup.
  20. #20 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Yeah probably sends signal voltages for the commands probably exactly how a steering wheel adapter does. Very nice. I see now why when hooking up the aftermarket harness you lose the 2 top speakers in the back of the bose system. 2rear tweeter are only out the 24 amp side
  1. Pioneer AVH-P2400BT?
    By Kilroy in forum Audio, Security & Visual Electronics
    Last Post: 04-06-2013, 10:50 AM
  2. Pioneer's 2000 Navy Blue GTP.
    By PioneerGTP in forum Members Rides
    Last Post: 01-07-2013, 05:32 PM
