Thread: Service Parklamps HELP
Results 1 to 4 of 4
  1. #1 Service Parklamps HELP
    Oxford,Michigan
    Hi All. I have a Service Parklamps alarm in my 2004 Grand Prix.
    I found I have a blown 10 amp fuse in the pass. side door block. My parking lights (yellow) and rear tail running lights did not work. everything else does (headlights, breaks, turn)
    I replaced the fuse, and everything works again, today driving to work, The service parklamps alarm came on again when I hit a bump, I got to work and the fuse was good. then on the way home, the lights worked again, hit a bump again and they went out, this time when I got home, the fuse was blown.
    When the parking lights don't work when the car is parked with the car running and in gear. I shut the car off and set the alarm, the parking lights will still flash.
    anyone have any ideals where to start?
  2. #2 Re: Service Parklamps HELP
    GTP Level Member simbah's Avatar
    Lala land
    remove your tail lights and look for a pinched wire or bare wire shorting to the body of the car. if you find a pinched wire then repair it and you should be good to go.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: Service Parklamps HELP
    Oxford,Michigan
    Does anyone think a bad relay could be causing it?
  4. #4 Re: Service Parklamps HELP
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by missyfisch View Post
    Sounds like a short somewhere. A relay could be causing it, but more likely to be a pinched/shorted wire as already mentioned.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. ABS Service, Traction Control Service & variable effort steering.
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 06-10-2017, 08:43 PM
  2. Replies: 5
    Last Post: 02-01-2017, 09:35 PM
  3. Replies: 14
    Last Post: 09-29-2012, 06:45 AM
  4. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  5. Serivce Parklamps
    By lolwtf in forum General Tech Discussion
    Last Post: 03-04-2011, 10:35 PM
