Thread: Driver Side Rear Deck Speaker
Results 1 to 12 of 12
  1. #1 Driver Side Rear Deck Speaker
    Aug 2013
    United States
    I just recently got a 2004 GP GT2 and the driver side rear deck speaker is not playing any sound at all. Even when faded to just that speaker there is no sound. Is it blown or do I need new wiring or what?
  2. #2 Re: Driver Side Rear Deck Speaker
    my regal did the same thing, speaker was blown to hell, along with the rest of them, after getting them out i was shocked they made any sound.
  3. #3 Re: Driver Side Rear Deck Speaker
    Aug 2013
    United States
    Well I got my GP from my grandpap who just recently died and he barley listened to music and the car only has 33k on it so I'm trying to figure out why it would be blown already.
  4. #4 Re: Driver Side Rear Deck Speaker
    Feb 2013
    37.295091, -121.930053
    speakers are funny if you dont use them they age and get brittle. That could be what happened to yours.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Driver Side Rear Deck Speaker
    just age im sure could kill these paper cones the factory uses. not one of my speakers had anything left conecting the cone to the metal frame of the speaker.
    you should be able to see the wire connection from under the deck, via the trunk. to make sure its plugged in.
    but to remove the speakers they come out from the top, the back seat needs to come out then the rear deck lid cover comes off, then you can take the speakers out.
  6. #6 Re: Driver Side Rear Deck Speaker
    Aug 2013
    United States
    Ok guys thanks a lot for the information. I'll probably just replace the speakers.
  7. #7 Re: Driver Side Rear Deck Speaker
    i added a sub and amp to my stock radio when i installed my new speakers, nice change in over all sound, with a bump bump bump now.
  8. #8 Re: Driver Side Rear Deck Speaker
    Feb 2013
    have scotty go boom boom boom.. boom boom boom.. LOL
  9. #9 Re: Driver Side Rear Deck Speaker
    Aug 2013
    United States
    I would love to add subs and new speakers all around plus a new hu but im just a college kid and i dont have a job now so i have to save up the money i have left.
  10. #10 Re: Driver Side Rear Deck Speaker
    well theres always used speakers off Craigs list. not always a bad way to go. im sure you could find 2 6x9 speakers for cheap.
    i got my amp for free, used from a friend, so it was easy on the wallet to finish up. went with a single 12 inch in a sealed box.
  11. #11 Re: Driver Side Rear Deck Speaker
    Aug 2013
    United States
    I was thinking about craigslist for subs and i found some nice rockford fosgate 6x9s that are supposed to be good for the kind of music i listen to for only $63.65 on amazon so ill probably get them
  12. #12 Re: Driver Side Rear Deck Speaker
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by gmildner13 View Post
    Try swapping the right side speaker with the left side. If yours is a Monsoon system, there's a bit of wire there to play with, but I'm not sure there's enough without pulling the speakers.
    If you have to pull the speakers, you need to pull both C pillar trim panels, (one screw each under the airbag emblem, then clips) the rear seat bottom, (sort of a "T" handle cable under the left and right sides about a quarter of the way in from the outside of the seat) the seat back, (four 10mm socket bolts along the top, three 18mm nuts at the bottom, including the seat belt buckles, and two 18mm socket bolts on the outer ends of the bottom edge.) Snake the three seat belts through the package shelf trim, then pull the trim out. The speakers are held in by two clips.
    If you have the Monsoon system, there will be two plugs for each speaker. One is for the "sub," the other for the mid range speaker. Make sure you don't mix them up. If I recall, the solid color wires are for the mid range, the wires with the tracers are for the subs.
    Since each speaker unit contains two speakers, it's entirely possible that the speaker unit itself is bad, but I wonder how likely it is. The odds of both speakers within the unit being bad aren't really all that good. As I understand the system, the rear channel mid range are separate channels with the higher frequency sound sent to each speaker by the built in crossover in the amp. The "subs" are a single output from the amp split to drive each speaker. This paragraph presupposes a Monsoon system. That's easy to determine. There's a center speaker in the dash that says "Monsoon."
    If swapping the speakers fixes nothing - you've got nothing to lose but about a half hour or so of your time removing and reinstalling the rear seat - I'd be inclined to believe the head unit in the dash is bad before I'd look at the amp.
  1. Rear Deck Speaker Replacement
    By Lishap in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2013, 01:05 AM
  2. Remove rear speaker grill, not the whole deck
    By BeastGT in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2011, 03:41 PM
  3. Rear Deck Speaker Installation
    By garreTT in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2011, 12:43 PM
  4. Driver Side Speaker
    By dacaster in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2010, 08:00 AM
  5. Rear Deck Speaker Grilles
    By SlowNA06 in forum Audio, Security & Visual Electronics
    Last Post: 05-25-2010, 12:18 PM
